20 Most Recent
Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas Questions & Answers
Error codes
I am having the exact same problem. Same codes flashing. If you solved it let me know. I had just replaced the thermistor and Stack flu sensor and it was running fine. Previously it would read 126 and not fire, so I changed those 2 items and it ran fine for the last month. When I go out tonight 2/24/22 and the panel is lit up and reading a code. I shut everything off at the circuit. Flip it all back on and it gives all those codes. It will fire and start heating when I switch valves for proper pressure but doesn't let you adjust temp on the panel and just reads a code and won't shut off. Any help in troubleshooting. Thanks.
LO on Display
"LO" means lock out. This means that the heater has failed to fire, and will not attempt to do so again until it is turned off and back on.
Either the heater is getting no gas, the gas valve is not opening for any of several reasons, the signal to spark is not being sent to the ignitor, the ignitor has failed, or the heater is failing to detect that the burner has been lit. Best to get a tech on it.
The heater won't fire and water temp reads 114
If the temp reads 144, the heater will not fire because it thinks the water is 144 ... entirely too hot and way beyond the safety limit of this heater.
I believe your trouble is in the thermostat sending unit.
Let me know what happens when you check this sensor.
Thanks for using FixYa.com
please vote
a
Error 181
Look on the panel of the heater, does it say service heater or service system? It sounds like you might have a dirty filter.
Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
What removals firm will Gordon Brown be using tomorrow?
Yeah,
but think how long he has been in office, because of the pain and
suffering to the average citizen under the Conservative years.It would
go to show society is thick if Cameron gets in just because they spend
their donations from big business donors on lots of advertising, and
Murdoch has spread a lot of propaganda for them just because they will
expect rewards from the Conservatives after, and it won't be for the
good of society.The
Sun treats its readers as idiots, and I'll agree that they are if they
vote for who Murdoch wants, just because the Conservatives will reward
him. You can see more in here about removals essex.
SR400NA will not fire.
It is possible there is no gas pressure or the gas pipe contains more air than gas. There is a port with a plug in it close to where the gas enters the valve body. If you carefully loosen to plug a small amount of gas will leak out if there is gas pressure. Make sure you don't screw the plug all the way out or you may loose it. If there is no pressure then you know that a valve is turned off upstream of the heater somewhere. If there is gas pressure then when the gas valve is energized you should be able to hear gas or air coming through. If you hear this gas and the ignitor is not able to light it then either there is something wrong with the ignitor or the gas has too much air in it. Another possible problem is if there is dirt or rust in the gas line it could clog parts of the system like the a regulator, valve or orifaces. I hope this helps.
Please vote on this answer. Thank you.
