20 Most Recent Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Questions & Answers
0answers
128 error code
Be the first to answer 10/1/2017 2:06:39 AM • Sta Rite... • Posted on Oct 01, 2017Be the first to answer
How to Upgrade from nine pin to six pin sta-rite replacement membrane
Just use the six pins that line up with the connector and leave the other three alone, starting from the top of the board.
4/6/2017 10:11:07 AM • Sta Rite... • Answered on Apr 06, 2017
How do you bypass the thermister
You can NOT bypass the thermister on a Sta-Rite heater. It needs a value to compare with on the control board. If you happen to have a fixed resistor available you can use one to test the heater. 7.5k ohms should work.
11/4/2016 9:57:43 PM • Sta Rite... • Answered on Nov 04, 2016
I have a SR400NA that has the PR LED light illuminated on the circuit board. I have checked continuity across the pressure switch and it opens and closes. In either case the PS light never goes off
check for blown fuses also check the thermisters they are also in safety circuit check to see if 24 volts at brown wire on gas valve using yellow as ground
6/10/2014 1:11:08 AM • Sta Rite... • Answered on Jun 10, 2014
Hi I moved into a
I recommendyou call the Sta Rite technical support line at 888-782-7483 and they should be ableto help you figure this issue out. Ihope this helps.
9/27/2011 12:11:29 AM • Sta Rite... • Answered on Sep 27, 2011
My Sta-Rite poll heater doesn't
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
9/14/2011 1:06:17 AM • Sta Rite... • Answered on Sep 14, 2011
I have a Sta Rite
It could just be the readout that's failed but there's no way of knowing unless you know someone else who has the same unit and you can try their readout.
The 42001-0096S has been replaced 42002-0007S as detailed on the following page where you can also purchase a replacement readout.
http://www.discountpoolmart.com/product_info.php?products_id=2765&osCsid=4csdf7fnpq38th489s1dh6uif0
Details for Flue Sensor requirements on 42002-0007S are available at the following link.
http://www.discountpoolmart.com/product_info.php?products_id=1480&osCsid=4csdf7fnpq38th489s1dh6uif0
These are probably the cheapest you'll find as most places are quoting $330 for the PCB.
In the long run it's probably worth just replacing both parts with new units.
5/27/2011 9:37:59 PM • Sta Rite... • Answered on May 27, 2011
The heater won't fire and
The SERVICE SYSTEM light indicates that there is insufficient
water flow to the heater. If the pump is operating, this
usually indicates that the filter and/or skimmers should be
cleaned (some filters may require backwashing). If the light
remains on after the filter/skimmers have been serviced,
the system should be checked by a qualified service technician. (from the manual))
If you clean the filters, and know the pump is pushing enough water, replace the water pressure switch, or test it first by jumping the 2 switch wires.
If this still is not the issue everything else is way to complicated to relay through an online media. It would be best to call a certified PENTAIR technician to solve this issue. As these heaters are very proprietary and their codes can mean many things, make sure you get somebody with experience on this model.
Below is a link to find a tech in your area.
http://www.pentairpartners.com/dealerlocator/dealerlocatorlist.aspx
4/11/2011 10:22:04 PM • Sta Rite... • Answered on Apr 11, 2011
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
42 questions posted
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Sta Rite Pool & Spa
  • Sta Rite Pool & Spa
Most Popular Question
sta rite pool heater fire
  • Pool & Spa
