HP cp1700 Color Inkjet Printer Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm not sure if this is a printer driver problem or a network problem. I have 3 computers networked (1 Vista, 2 XP)all using a CP1700 through a jetdirect print server. The vista computer works more or less ok, the 2 XP computers will only print 1 copy of a document no matter how many are requested. Any suggestions?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Expert 85 Answers
  • Posted on Jan 04, 2010
Anonymous
Expert
Level 2:
Mentor:
New Friend:
Answers
85
Questions
0
Helped
18340
Points
242
So your printing to a network IP port? I don't this the setup is the problem if the computers see this printer as a network printer. I believe this to be a driver problem. I would try either a 5e or genric driver of some type. I'm not sure what type of printer this is so...
My printer isn't printing
Solution 1 On the Computer:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Solution2 On the Printer:
1. Go to Set-up 2. Go to Network Set-Up 3. Choose Restore Network Defaults 4. GO Back and then Choose WIreless Set-Up WIzard
1helpful
Hp officejet 3680 not printing
1helpful
Drivers for ethernet card for gateway 6433 laptop
That unit has multiple drivers depending on os and original configuration as shipped. All are available at the mpcdrivers.com website at the following links.
http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN2.exe - Windows Vista Intel Wireless Network Driver version: 11.1.0.86
Supports: Windows Vista (32-bit)
Note: This file contains the Windows Vista network driver for the computer models and components listed below.
3/13/2007
190,957 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/VIWLAN.exe - Wireless Network Driver version: Intel 10.6.0.46
Note: This file contains the Windows Vista network driver for the Gateway notebook computer models and components listed below. English, Japanese, and Spanish installation instructions are included in the file.
2/7/2007
3,633 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/LANFAQ.exe - LAN Windows Vista Driver Information
Note: This document explains the networking functionality within Windows Vista for the computer models and components listed below. English, Japanese, and Spanish instructions are included in the file.
2/1/2007
27 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/BCM40100.exe - Broadcom Wireless Driver Version 4.100.15.5
Supports: Windows XP
Note: This is the Windows XP Broadcom Wireless driver for the Gateway notebook computer models listed below.
11/28/2006
77,858 KB
http://www.mpcdrivers.com/sylvia/Support/gateway/D00453-001-002.exe - Network Driver version: 8.26.2.3
Note: This is a Windows XP network driver for the Gateway notebook computer models listed below.
1helpful
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Network printing in vista is offline
Is it shared over a network, or is the driver installed on each PC independently? Have you installed the proper Vista drivers on the Vista PC's? The Xp driver is likely not compatible with Vista. It may be (if you used a disc) that it doesn't contain the proper Vista drivers. I would try downloading the proper driver and re-installing on the Vista PC's.
get it here:
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc8460n_all
Can't find printer on network
1.How are you attaching to the network printer from your daughters computer? IP address, or by the name of the printer...Also make sure you check you are attaching to the network printer, and not local printer.
2. Install the Microsoft TCP/IP version 6 protocol on both computers by clicking install on your LAN properties, then restart PC. This should work!
1helpful
LP2884 not recognize by one of the computers
Make sure you download the Zebra Designer Driver for the Vista computer. The Zebra Universal driver does not work with Vista. Vista Driver Link
1helpful
Can I share 1 printer with 2 computers 1 Vista 1 XP with the hub?
Yes you can share out one printer from 2 computers. you can either set up a home network using arouter to connect your 2 computers. Or you can use an a /b switch to share the printer.
3answers
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
k24674
Grand Canyon Tech
Grand Canyon Tech
