20 Most Recent HP Inkjet 1200dn Printer Questions & Answers
WOULD LIKE TO PRINT STUFF OF THE COMPUTER
HP Inkjet 1200dn... | Answered on May 17, 2017
Try running the alignment program.
It should fix the problem.
HP Inkjet 1200dn... | Answered on Dec 01, 2013
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
HP Inkjet 1200dn... | Answered on Apr 06, 2013
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
HP Inkjet 1200dn... | Answered on Feb 20, 2013
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
HP Inkjet 1200dn... | Answered on Dec 12, 2012
first try to on device without cartridgeif not on then your device not boot so u go to service station there are some hardware problem
HP Inkjet 1200dn... | Answered on May 17, 2012
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
HP Inkjet 1200dn... | Answered on Dec 01, 2011
Unfortunately, you are correct. HP has not developed the drivers you need in order to get your printer to work with anything above 10.5. Your options are to downgrade to 10.5, get a different printer (check for compatibility with 10.5 before buying), or wait for HP to offer this driver at some point in the future. I wish I had a different answer. Sorry. :(
HP Inkjet 1200dn... | Answered on Sep 21, 2011
Please open the document, There is probably a second page added to your word document.
Open the file, go to page 2, press backspace.
When you select print option, now check how many pages its showing for printout.
If its showing one page then your file is perfect now.
HP Inkjet 1200dn... | Answered on May 19, 2011
All you have to do is register and create your own user id and password, there's no cost involved, and then you should have access to what your looking for
HP Inkjet 1200dn... | Answered on Jan 02, 2011
HP Inkjet 1200dn Printer Logo
64 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
InkJet HP
  • InkJet HP
Most Popular Question
yellow light front printer
  • Office Equipment & Supplies
