20 Most Recent
NetGear WGR614 Wireless Router Questions & Answers
Router Suddenly stopped working...?
try power cycling your network (turn off all of the hardware)
First turn off the computer,
second, the router;
lastly the router (wgr614).
Now, turn the hardware in this order:
- Turn on Modem. Wait 2 minutes.
- Turn on Router (wgr614). wait 1 minute.
- Now turn on the Computer(s).
this should refresh your internet connection. If not, check your routers settings for any wrong info.
to access your router's homepage, type this (http://www.routerlogin.net) into Internet Explorer.
My ps3 to this netgear router isn't connecting with WIFI.
Playing Online Games Behind The Router
A router uses a
combination of hardware and software to prevent unauthorized users or internet
traffic from accessing your private local area network (LAN).
If your game console, such as Playstation is behind the router, you will need to
configure routers Port Forwarding feature in order to play online games.
Note: You will need to get the ports and service type for your
games. This is usually available from the games website.
Steps how to configure router to
play online games:
Open a browser and
type in the following URL:
http://www.routerlogin.com or http://192.168.1.1 (depending on the
model number of the router)
Type the Username
as admin and the Password as password and click OK.
Click on Port
Forwarding under Advanced menu.
Then click on Add Custom Service
5. Under Service Name, type the name of the game.
Select the Service Type from the drop down menu (depending on the
game).
Type the Starting Port and Ending Port numbers (depending on the
game).
Type the IP address of your PlayStation in the Server IP Address box
and click Apply.
Click on WAN Setup under ADVANCED menu.
- Check the Disable SPI
firewall box
Change MTU size from 1500 (which is the default) to 1300 and click
Apply.
Now the Playstation is ready to use.
I hope this helps...
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Trying to find password or
To access the router:1. Type http://www.routerlogin.net in the address field of your browser, and then click Enter.2. When prompted, enter admin for the router user name and password for the router password,both in lowercase letters. (For security reasons, the router has its own user name andpassword.)3. On the main menu, select Wireless Settings to display the Wireless Settings screen.Note that the default SSID is NETGEAR.4. You will now see your wireless Security Option and passphrase. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
HP DESKJET D1360 HOW TO SET UP WIRELESSLY USING MAC
Are you trying to use MAC filtering. You would just need the MAC from the network setup screen and add it to your router/firewall.
If you are using a Mac (Apple) computer you would, providing you have a wireless adapter connected to Mac, just go into "System Preferences" and use the wizard under "Print & Scan". Make sure the networking on the printer is in on the same as your Mac.
How to reset netgear wgr614 to factory default
You
can reset your Netgear router to the factory settings from within the
router manager. The reset procedure removes all user-configured settings
and returns the router to the original factory settings. For this
reason, only reset the router if you encounter problems that can't be
solved with other methods.Step 1:
Check that your Netgear router is properly connected with your system
or not. If it is OK, then press reset button on Netgear router for at
least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'.
This process will erase all your previous changes that have been made
to the router and restore the configuration settings to factory setting.
Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset. Get instant Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Info on how to reset the router
You can factory reset the router using the small button on the back,
hold it in for 30 seconds with the power on to the router. This will
clear all settings from the router including the password, so you will
need to set up the router again after the reset.
Cannot reset my password on my router made by
Power up the Netgear and press the pinhole RESET button on the back of the Netgear until all the LEDs flash, then release the RESET button.
The Netgear is now restored to the factory default settings.
How do i reset my netgear wgr614v10 router to
Hi there!
Take a paper clip, and insert it into the
little reset hole in the back of the router... hold for at least 20 seconds.
username and password: the defaults are admin and password..
Hope this helps
levibit
