20 Most Recent Zebra LP 2844 Thermal Printer Questions & Answers
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
11/21/2021 7:55:02 PM • Zebra LP 2844... • Answered on Nov 21, 2021
Zebra only prints after restart
UPS VOLTEGE PROBLEM PLEASE INSTALL HIGH VOLTGE UPS
11/21/2021 7:54:33 PM • Zebra LP 2844... • Answered on Nov 21, 2021
6answers
Zebra LP 2844 doesn't stop feeding paper
I had the very same problem but I know it could be several different reasons. In my case it was a media calibration issue. To perform calibration switch the power OFF, then pres FEED button and hold it, Power ON still holding and after three red flashes release it. Calibration report will print out. At the end of that print you should get "PRESS FEED TO END". Do it and it should be ok. Let me know if that worked.
11/21/2021 7:41:41 PM • Zebra LP 2844... • Answered on Nov 21, 2021
Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
11/21/2021 7:38:51 PM • Zebra LP 2844... • Answered on Nov 21, 2021
Zebra 2844 Printer was fine...unplugged
This is due to windows which has attributed a new virtual usbport.
Go to the printer port and try another one (the last one for example)
11/21/2021 7:37:08 PM • Zebra LP 2844... • Answered on Nov 21, 2021
2answers
Printer is working but labels are blank
you need to have thermal direct labels to print to a thermal printer. heat turns the paper black. check your labels to see if you have thermal direct or tuern darkness up if it is thermal direct paper
10/10/2019 9:23:40 AM • Zebra LP 2844... • Answered on Oct 10, 2019
2answers
Zebra Thermal 2844 prints text poorly
Lizardlick,
I found this information in the user manual:
Let the print head to cool for one minute, then use a new
cleaning pen to swab the print elements (the thin gray
line on the print head) from end to end. NOTE: You do
not have to turn off the printer to do this.
If print quality remains poor after cleaning, try the
Save-a-Print Head cleaning film to remove buildup
without damaging the print head. Call your authorized
reseller for more information.
12/26/2017 2:44:58 AM • Zebra LP 2844... • Answered on Dec 26, 2017
Is it my pc or my zebra printer?
Go into printer options and select "Fit To Page"
9/7/2017 10:12:56 PM • Zebra LP 2844... • Answered on Sep 07, 2017
0answers
Zebra LP 2844 Thermal Printer Logo
527 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Zebra Office Equipment & Supplies
Most Popular Question
working zebra lp2844 label printers
  • Office Equipment & Supplies
