I've replaced the maintenance kit on an HP P3015 and there's no obvious instructions in the service manual to reset the page counter for the next maintenance kit replacement. Does anyone have the instructions
If you need a service manual for this printer the you need slip-ons.
SOURCE: How do I reset the page count on a HP Laserjet
the total page count cannot be reset, if you wish to reset consumable counts replace relevant consumable. thanks
SOURCE: i have hp printer 4700 color laserjet .i installed
What I recommend you to do is turn off the printer, disconnect it from main power for a couple of minutes and then connect back and then turn on and counter suppose to reset by itself.
SOURCE: Installing Fuser kit
are you a service eng. or a User isf you are a user you have be more care when you diassemble it . It can cause malfuntion I can get you a service manule for this . or check google for that
SOURCE: HP 4345. Need to reset the Maintenance kit error.
To reset the maintenance-kit counter
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Sean, thank you for the suggestion. There are no LED lights on the P3015. It has an LED display screen. Are you possibly thinking of the HP P2015?
