20 Most Recent Lexmark T642 Laser Printer Questions & Answers
T642 wont recognize tray 2 or duplex
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
7/31/2021 7:28:06 AM • Lexmark T642... • Answered on Jul 31, 2021
We can't get the lexmark t642 printer to work at home
The printer is not hooked up to the wireless network. It will work if hooked up with an ethernet (hard wire) cable. Anyway, it is a royal PIA to set up - let him take care of it.
9/1/2017 5:44:26 PM • Lexmark T642... • Answered on Sep 01, 2017
What can i do when my lexmark T642 printer displays 922.02 service fuser error when the printer was never used?
It could be the connector to the fuser from the LVPS is not connected properly. It could also be the Thermistor on the fuser is bad.
3/20/2017 3:36:55 AM • Lexmark T642... • Answered on Mar 20, 2017
2answers
Error message says: remove paper from standard
Make sure that the exit flag is moving freely. It sounds like it is stuck in the up position or popped out of place. The flag is located on the left side of the output bin and should be hanging down
8/20/2015 5:59:57 PM • Lexmark T642... • Answered on Aug 20, 2015
927.03 service fan stalled
hello This solution was tested for x 204. Get the right cover of the printer. See the fan. Fan connector is located to the card enters the socket. Socket located at the bottom part of the written 4R7. Install this part by removing the 4.7 ohm resistor. The problem is solved.
8/1/2014 11:42:47 AM • Lexmark T642... • Answered on Aug 01, 2014
0answers
0answers
2answers
Lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
8/8/2013 6:30:46 PM • Lexmark T642... • Answered on Aug 08, 2013
0answers
900.56 error
Be the first to answer 3/15/2013 3:16:56 AM • Lexmark T642... • Posted on Mar 15, 2013Be the first to answer
Lexmark T642 Laser Printer Logo
170 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
T Lexmark
  • T Lexmark
Most Popular Question
927 03 service fan stalled
  • Office Equipment & Supplies
