GENERAL REFERENCE
Hewlett Packard 49.XXXX Errors
I hope this will be of assistance to you, any repairs under taken are at the owners free will.
Hello, the dreaded 49.2F9D Error Turn Power On/Off and other related 49 Errors.
This tip relates to the Hewlett Packard P3005 Series Printer - General reference to most HP Laser Printers
There have been many reports of this error in the HP genre of laser printer. This is a generic fatal error; the root cause is undetermined in most cases. It could be related to an application "corrupt data" or faulty printer firmware, or the formatter board or other associated hardware or accessory.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. A new firmware file can be found here. P3005FIRMWARE
Pay close attention to PDF files with embedded JPEG files.
Pay close attention when printing Emails or Web Pages.
In rare circumstances the fuser has been reported to cause the 49.2F9D error. (P3005 specifically)
*** Further Reference Material MoreOn49Errors ***
*** Hewlett Packard Support Page HPSUPPORT ***
Contact a local HP Authorized Service Center for further assistance.
Thank you for contacting FixYa with your printer inquiry.
This error message prompts when paper or obstruction holds a
sensor switch or toggle open in the paper path. Paper can jam a sensor and make
it think there is a jam when there isn't one.
Action:
It's possible the fuser has been changed out and the
incorrect replacement has been installed. You will want to confirm the part
numbers if so.
If the DC Controller has been changed you will want to
confirm connections.
Hope this helps. Please keep us updated and remember to rate
this answer.
TF
220 questions posted
1,429 Questions
1,001 Questions
724 Questions
663 Questions
593 Questions
