20 Most Recent Sta Rite STA-RITE POOL PUMP LID, TINTED - C3-139P3 Questions & Answers
Lid placement
bit of a trick and you must use force it will eventually come out of the ring. new one seems to go in in easier tho
7/28/2018 4:24:58 AM • Sta Rite... • Answered on Jul 28, 2018
We have a Sta Rite SR400NR when we turn it on we an error code 180 then c 8 then it shuts off
Check the control wire that might be connected to the control fuse. If that wire is open the unit will only cycle thru the board information and the sit dormant until the control is called for.
5/1/2020 6:06:40 AM • Sta Rite Pool &... • Answered on May 01, 2020
0answers
0answers
WATER WELL WILL NOT PRIME OR PUMP WATER
replace the mechanical shaft seal. check impeller and diffuser for damage . prime pump after any repair
12/2/2017 7:36:46 AM • Sta Rite Pool &... • Answered on Dec 02, 2017
Sta rite SR200LP Heater will not fire. Your answer was “bad flame sensor “. Where is the flame sensor or what part is it? Is it the same ignitor?
Sears runs a resource called Parts;sDirect, you can get parts for appliances, tools, lawn equipment,etc.
Need the model and serial #, it'll have exploded views of the different subsections. All.parts on the exploded views are numbered & correspond to a catalog page alongside the picture, with the cost
posted. I've used it repeatedly, very accurate, prices are competitive.
11/23/2017 7:43:07 AM • Sta Rite Pool &... • Answered on Nov 23, 2017
We have a SR200 NA Sta-Rite heater on our pool. We just replaced the thermistor today. Now the digital temperature readout keeps jumping back & forth between 91 & 104. (water temp. was only ab
That unit has specific instructions for water temp operation at 60 or lower. The display also can show diagnostic info and there are indicator lights for diagnostics. Do you have any of those showing any errors? If the temp is jumping from 91 to 104 instantly and then back down to 91 instantly, this is a wiring issue or a bad thermistor. Check the wiring and use an OHM meter to check the thermistor, it should have a chart that shows a resistance at a certain temp. There is a limit switch right next to the thermistor, Make sure it is not shorting out with that.
11/21/2017 5:52:50 AM • Sta Rite Pool &... • Answered on Nov 21, 2017
Sta Rite STA-RITE POOL PUMP LID, TINTED  - C3-139P3 Logo
1 questions posted
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Sta Rite Pool & Spa
  • Sta Rite Pool & Spa
Most Popular Question
lid placement
  • Pool & Spa
