20 Most Recent
HP DeskJet 1280 InkJet Printer Questions & Answers
Instal hp dekjet 1280 with
Wireless printers may face an installation problem with Windows 7 operating system. For example, Toshiba laptop is compatible with this operating system yet it may require a driver download for executing a print command on
wireless printer. To combat this challenge, users are advised to delete and re-install the printer. If the problem persists assign the wireless printer to a fixed address through a router instead of the Dynamic Host Configuration Protocol (DHCP). Accessing the wireless printer from a laptop with Windows 7 operating system can be a challenge. Often, it may display the printer to be offline. To resolve the issue, users must cancel printing jobs immediately and delete offline printers from the Printers option in the Control Panel. Visit the Printer properties and access the Ports tab, delete the printer that displays the offline status and appears as Client Side Rendering Provider. Delete the Port button and click apply. Restart the PC. Now re-install the wireless printer by visiting the Control panel, opening Printers and clicking option add a printer. Now select add a local printer, followed by selecting the option "Use an existing port", LPT1: (Printer Port). Install the printer driver offered by Windows 7. In the next window leave the Set as a default printer box unchecked and re-name the printer. Click Next. Upon successful installation, the operating system will display the message "You've successfully added printer name"
My deskjet 1280 simply Won't turn on.
Hi
A couple of times this has happened to me and it is to do with the access port at the back of the printer ie it has a lock - unlock symbol on it and a circular handle. Make sure that this is firmly in the locked position. Note that it may seem to be in the locked position but often there is a little bit more it will go ... though dont force it so that it breaks ... try unlocking and firmly locking a couple of times, each time testing the on button. Like I said this has worked for me before
Regards
Mark
Hello sir,
Windows 7
AutoCAD
if everything else works ok except AutoCAD then the problem is not the printer, it is a broken data connection between AutoCAD & the printer. Sometimes all it takes is to unplug & replug the cable, or restart the pc with printer already connected.
3 light blink
If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Search the site by type in the brand name to your device, in the "
Search box at the top right of the display window".
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Am hving hp deskjet 1280
hi
I think you must check some things like:
- usb cable is good cable and work correctly.
-your computer USB ports works correctly.
-the power is connected to printer and its work and its leds plink.
-you choose the write driver.
