20 Most Recent
Actiontec GT704WG Wireless Router (gs583ad3-01) Questions & Answers
Router configuration
i sujject you learn CCNA - cisco certified network associate course ware .. then you can configure most of the routers with slight syntax changes
good luck
2/1/2019 5:38:54 AM •
Actiontec...
Answered
on Feb 01, 2019
Am I getting high speed thru my actiontec gt704wg
It depends on your DSL connection- technically anything above 56k is "high-speed internet"- if you are concerned about the speeds you are getting, contact Verizon tech support for further assistance- you could have an issue with your connection, and they would be the ones able to setup for a technician to come out/ have the maintenance office repair the connection I’m happy to help further over the phone at
https://www.6ya.com/expert/susan_42b401e0b1603d8a
3/6/2017 11:37:59 AM •
Actiontec...
Answered
on Mar 06, 2017
Hi I want to know
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported. I’m happy to help further over the phone at
3/6/2017 11:32:28 AM •
Actiontec...
Answered
on Mar 06, 2017
Verizon GT704WG DSL Modem wants me to install software
If my memory serves me, I didn't install the software for my Actiontec modem/router combo. I call Verizon and told them I refused to install the software and they helped step me through getting rid of this garbage. You should never have to install software to get a modem or router to work as any software the comes with it, is simply used to provide easier configuration.
Since I couldn't find anything about bypassing this software, I would suggest contacting Verizon directly. Their technical support should be able to assist you.
8/24/2015 4:14:28 AM •
Actiontec...
Answered
on Aug 24, 2015
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
9/2/2014 6:37:36 PM •
Actiontec...
Answered
on Sep 02, 2014
FORGot passphrase for router
you can factory reset the router and then it should allow you to create a new password. Hold reset button in back down for 12+ seconds. be advised this will reset all router settings back to factory defaults.
8/13/2014 4:23:21 PM •
Actiontec...
Answered
on Aug 13, 2014
Why are all lights out router
1. not plugged in
2. bad outlet
3. the on/off switch on the back is set to the off position
4. bad power supply unit
if it doesn't turn on after checking all this then you need a replacement.
8/13/2014 3:30:41 PM •
Actiontec...
Answered
on Aug 13, 2014
Error "virtual server add error" failed. stats: 1
I had this error. There was an old rule for an old device that was no loonger connected. If a device that has a rule is not connected, no information will show up telling you there is a rule. But it already exists and is hidden. The rule will only show up when the device is connected. But the rule is active wether or not the device is connected.
The only .I found to fix this is to reset the router to defualt settings, this will remove the old device and it's tules from memotry.
2/26/2014 10:28:18 PM •
Actiontec...
Answered
on Feb 26, 2014
Password reset
Hey;
While the router is turned on, look in the back and locate the reset button. Press and hold for 10 to 15 seconds and then release. The router should reboot and return to factory settings.
Go to the router page and use the fallowing to log in.
User: admin
Pass: admin
You can re-enter all router info after login.
2/18/2014 12:32:25 PM •
Actiontec...
Answered
on Feb 18, 2014
Security key
Look on the underside of the Router. it is usually marked on there. look for a WEP or WPA with a number.
7/24/2013 8:20:48 PM •
Actiontec...
Answered
on Jul 24, 2013
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.May be it can be cause of Incorrect wireless network setup & configuration. Recheck and
correct the Ethernet connection between your PC and the router device.***If you need any kind of technical assistance you can contact
support cell at here
2/1/2013 5:50:05 AM •
Actiontec...
Answered
on Feb 01, 2013
