If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
Testimonial: "Thank you, took out normal alkaline batteries charged up old NI-MH batteries and it's sprung into action ! Thanks again. Catherine N Wales"
If you have the latest driver downloaded so your pc can recognize the camera, first run the pic transfer program, then turn on camera, then lastly connect camera to pc via usb cable. Usually as soon as you plug in the camera it should ask if you want to transfer pictures. If it doesn't ask, then the driver probably needs to be updated or software needs to be reinstalled and pc restarted
My olympus c-315 zoom camera will not switch on after the batteries were recharged
