20 Most Recent Olympus Camedia C-4000 Zoom Digital Camera Questions & Answers
12answers
My screen keep showing the Card Cover Open Error even though the cover is closed
Somewhere on the door will be a small piece of plastic which when the door is closed makes contact with a microswitch which tells the camera the door is closed. Either this switch has broken or the piece of plastic has. Somewhere within the memory card receptacle you should find a small hole where the piece of plastic enters when the door is shut. Switch the camera on, leave the door open and push a wooden match or something of a suitable size made of plastic into this hole (be gentle) if the "door open" sign clears then the problem is with the prod built into the door. If it doesn't clear then the problem is with the switch. Actually this switch can be disabled or continually shorted out if it proves to be faulty. I have had a camera come in for an unrelated repair with the hole blocked up with plastacine to hold the swich closed. IT WORKED Stu
4/26/2016 3:55:17 AM • Olympus Camedia... • Answered on Apr 26, 2016
I ant find a place to download the pictures from my memory card!
Normally you select a folder on your computer to download images to - if this is causing problems, your computer manual should help.
4/2/2016 12:48:13 AM • Olympus Camedia... • Answered on Apr 02, 2016
Lcd screen not working on camedia c500 camera
recycle it www.ban.org
4/2/2015 10:32:17 PM • Olympus Camedia... • Answered on Apr 02, 2015
0answers
The top and right hand buttons on 4 button selector intermittent
There can be many causes, why the buttons don't work as the should. Also a bad connection, on a PCB or flat cable can be the cause. If you want to repair it yourself, visit ifixit dot com, there you can see manuals and videos about how to open a camera and where to look for.
2/15/2014 11:38:32 AM • Olympus Camedia... • Answered on Feb 15, 2014
The lens fell off my camera 2 pieces
Cost to much to replace it, Time for a new camera, TC
12/6/2013 2:57:06 PM • Olympus Camedia... • Answered on Dec 06, 2013
0answers
Card error
Be the first to answer 11/10/2013 8:00:21 AM • Olympus Camedia... • Posted on Nov 10, 2013Be the first to answer
4answers
Missing usb cable for olympus camedia c-4000 zoom
https://emporium.olympus.com/innards/emp.asp?val100=100&step1=869&step2=0
Here is the link to the online Olympus store website where you can purchase a replacement USB cable
7/22/2013 10:45:26 PM • Olympus Camedia... • Answered on Jul 22, 2013
2answers
Want to empty photos off card, loaded them onto
To completely erase the card, the best way is to format the card in the camera.
1/6/2013 7:30:44 AM • Olympus Camedia... • Answered on Jan 06, 2013
2answers
How do I download photos from my Olympus Camedia
either get a card reader to hook up to your usb on your computer this is easiest and dont have to download a driver for your camera if you dont have a disk. Or just get a usb for your camera and download them.
1/6/2013 7:29:56 AM • Olympus Camedia... • Answered on Jan 06, 2013
Need to replace flash
The flash is not consumer-replaceable. You will need to have it serviced and it will be very expensive.
10/23/2011 11:44:08 PM • Olympus Camedia... • Answered on Oct 23, 2011
Download for windows vista
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/12/2011 5:42:45 PM • Olympus Camedia... • Answered on Apr 12, 2011
I don't have the disk.
Hello there,
Have you tried viewing your camera's drive using Windows Explorer? Connect the camera using your usb cable to the computer. Then RIGHT click on the windows Start button and choose Explore to open windows explorer. On the window divided into two sections, look for the Computer or My Computer from the left. Under it, look for the drive letter associated with your camera. Then click on it to show the contents of the right. Now look for the folder containing your pictures then copy them on your local drive. Please take note that your camera should be in playback mode not shooting mode.
Hope this helps. THank you for using FixYa.
2/23/2011 4:57:26 AM • Olympus Camedia... • Answered on Feb 23, 2011
I am using Windows Vista
1/3/2011 12:00:50 AM • Olympus Camedia... • Answered on Jan 03, 2011
2answers
Please excuse my ignorance but will it turn on
It should turn on but you really should use a memory card.
12/24/2010 1:04:38 PM • Olympus Camedia... • Answered on Dec 24, 2010
Trying to use timer for
From the top menu, select MODE MENU then CAMERA then the one-handed clock then ON.
12/13/2010 7:04:48 PM • Olympus Camedia... • Answered on Dec 13, 2010
Olympus Camedia C-4000 Zoom Digital Camera Logo
100 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
screen keep showing card cover open
  • Cameras
