20 Most Recent Olympus Camedia D-540 Zoom Digital Camera Questions & Answers
Downloading photos
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa: Organize edit and share your photos
11/11/2014 10:06:30 AM • Olympus Camedia... • Answered on Nov 11, 2014
Can i change shutter speed on my camera?
Not much. The D-540 is designed as a point-and-shoot camera, which means you're supposed to just point and shoot, without bothering about such minor details as the shutter speed and the aperture. You have some control. For example, the Portrait mode will attempt to use a wide aperture to reduce the depth of field, which will result in a faster shutter speed, while the Landscape mode will attempt to use a smaller aperture to increase the depth of field, which will result in a slower shutter speed.More sophisticated (and heavier, and more expensive) cameras will give you more control, but this is about all you're going to get with most point-and-shoot cameras.
9/13/2013 11:00:17 PM • Olympus Camedia... • Answered on Sep 13, 2013
What do I do to download pictures from camera to computer?
I assume you had a memory card in the camera when you took those pictures.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
10/7/2012 5:10:32 PM • Olympus Camedia... • Answered on Oct 07, 2012
Olympus D-540 wont read on Mac (10.6). Is there a software update?
Go the the Olympus web site, and check for updates for your model, if supported they may offer Mac driver for the system.
3/18/2012 10:20:52 PM • Olympus Camedia... • Answered on Mar 18, 2012
D-540 broke
you cant just fix it by yourself it required a well trained technician to do the job,one more there are very high voltage inside the camera you would not believe it but theres a 300V on the flash capasitor,,,,
2/23/2012 10:53:50 AM • Olympus Camedia... • Answered on Feb 23, 2012
Hello. I lost program for
Whether you connect via USB or use a card reader, you can also use any photo cataloging program. iPhoto comes with Macs, Windows Photo Gallery comes with Windows. There are additional programs available, such as the free Picasa ( http://picasa.google.com ).
9/21/2011 7:44:22 PM • Olympus Camedia... • Answered on Sep 21, 2011
3answers
Camera won't switch on, put new batteries in
If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
8/30/2011 8:22:26 AM • Olympus Camedia... • Answered on Aug 30, 2011
Can I use a XD M+2GB picture card in my camera?
Yes you can use that memory card for this camera.
8/19/2011 2:55:54 AM • Olympus Camedia... • Answered on Aug 19, 2011
2answers
BATTERY SHOWS EMPTY WHEN TRY TO TAKE PICTURE
if its internal and have to charge it with a charger then you need to change the battery. i would recommend taking it to a camera shop and having it evaluated its well worth the evaluation trust me it might be something simple as just getting a new battery to a loose connection inside. Worse case you might have a bad indicator that needsto be fixed. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
8/9/2011 2:30:09 PM • Olympus Camedia... • Answered on Aug 09, 2011
Color on picture I get
The camera is quite old, I would guess that the image sensor has gone bad. The price of a repair is beyond the price of a new camera.
7/26/2011 12:52:18 AM • Olympus Camedia... • Answered on Jul 26, 2011
When I plug my usb
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
7/10/2011 3:05:44 AM • Olympus Camedia... • Answered on Jul 10, 2011
Can't seem to upload from
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/30/2011 4:52:26 PM • Olympus Camedia... • Answered on Apr 30, 2011
My camera wont upload pics onto my laptop
4/1/2011 5:25:48 PM • Olympus Camedia... • Answered on Apr 01, 2011
Cant download photos to computer
Having received no response in over five months, I assume my suggestion to use a card reader solved the problem.
3/28/2011 10:13:03 PM • Olympus Camedia... • Answered on Mar 28, 2011
What kind of memory card
It uses a XD memory card.
3/1/2011 4:22:18 AM • Olympus Camedia... • Answered on Mar 01, 2011
Camera won't focus on object sindce the picture
its likely that she may have hit the macro setting only allowing it to focus up close to objects to turn this off all you have to do is find a button that looks like a flower this could be on the arrow pad or in the menu system but it is called the Macro setting and with it turned off hopefully your pictures will be sharp again
3/1/2011 4:21:04 AM • Olympus Camedia... • Answered on Mar 01, 2011
Lost instruction manual and need
You can download and print the instruction manuals for Olympus Camedia D-540 Zoom Digital Camera in PDF format by clicking these links:
D-540 Zoom Reference Manual (English - 5.2MB)
D-540 Zoom Quick Start Guide (English - 818KB)
D-540 Zoom Basic Manual (English)
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
12/24/2010 7:43:59 PM • Olympus Camedia... • Answered on Dec 24, 2010
Try photo recovery software to rescue the lost photos, here are some you may rely on.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
12/16/2010 8:13:23 AM • Olympus Camedia... • Answered on Dec 16, 2010
Olympus Camedia D-540 Zoom Digital Camera Logo
71 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
camera won 39 t switch put new
  • Cameras
