20 Most Recent Nikon COOLPIX L18 Digital Camera Questions & Answers
"Battery exhausted" message with good batteries
make sure you have either lithium AA batteries or Alkaine AA batteries it happened to me before too and this worked
5/16/2018 4:39:25 PM • Nikon COOLPIX... • Answered on May 16, 2018
I have continuously had battery problems with my
Recharables as it will be cheaper since these are huge battery eaters NIkon is keeping the battery companies in business with you folks. BY all means find a diffrent brand you not the only ones with battery eaters!! Canon SLR, Pentax are the best battery savors in town. Quit feeding the energiser bunny and move on to better cameras is my recomendation and expert advice to you! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5/16/2018 4:38:58 PM • Nikon COOLPIX... • Answered on May 16, 2018
L18 exhaust batteries even when camera is turned
No you should alway store electronics that is not being used for a duration remove batteries
it you put the batteries in the freezer it also extends the life of the battery
5/16/2018 4:38:02 PM • Nikon COOLPIX... • Answered on May 16, 2018
Camera has blank white screen + crack from the inside out
The cracked screen is the whole problem Go onto Nikon's web page to get repair information.
10/19/2017 3:03:46 AM • Nikon COOLPIX... • Answered on Oct 19, 2017
Nikon Coolpix L18 suddenly states that card is not formatted.
Sounds as if the card is corrupted - you will have to use data recovery software.
8/6/2017 10:01:19 AM • Nikon COOLPIX... • Answered on Aug 06, 2017
Black Screen
Do more internet searches of your model. Sounds like the sensor chip died. Pretty expensive part. Could have not liked the salty environment or you are just unlucky. Do the search until you give up as there is a lot of info on internet. Cameras are getting pretty cheap now so if it is a little old or cheaper model, you may do better with a forced "upgrade".
5/20/2017 6:06:42 PM • Nikon COOLPIX... • Answered on May 20, 2017
Lens locked out position wont close
try taking out the battery and re;install.lens should retract.if not,switch off camera and very GENTLY try to push in lens,while camera is still shutting down.otherwise have it checked by expert.
1/4/2016 7:56:35 PM • Nikon COOLPIX... • Answered on Jan 04, 2016
Battery compartment won't open?
Push the cover toward the back of the camera and then toward the end, just as the arrow indicates, then the end of the cover nearest the end of the camera will swing open. Follow the illustration in the "Insert the Batteries" section of the manual (page 12 in my copy).
11/12/2015 11:55:39 PM • Nikon COOLPIX... • Answered on Nov 12, 2015
What is write protected
It probably refers to intellectual property protection i.e. copyright, trademark, patent etc.
5/30/2015 12:23:18 AM • Nikon COOLPIX... • Answered on May 30, 2015
How do I delete all pictures from my Coolpix L 18
Is there not a button with an icon of a bin next to it on your camera? You could also just hook your camera up to a computer, browse to the folder, select all the pictures and delete them like that.
3/2/2015 2:31:01 PM • Nikon COOLPIX... • Answered on Mar 02, 2015
2answers
My Nikon Coolpix l18 doesn't work. It turns on and display lights only with a white light but no images. What can I do?
Do you have a SD card in it are your batteries new and the right kind? Have you taken pictures with that camera before If you can answer yes to all those questions and you still have problems contact your vendor
1/25/2015 12:47:16 AM • Nikon COOLPIX... • Answered on Jan 25, 2015
Prongs inside mini usb port on camera nikon d40 bent
best thing to do is send it in for repairs but if your confident in opening it up then just make sure you take note of exactly how you opened up so you are able to put it back together again and then carefully bend the pins straight or how ever they were originally remember if over bent you run the risk of snapping the pins and then you will have to (and this is not often very easy to do)source the unit and then have the skills of soldering and this is also not very easy
11/27/2014 9:17:14 AM • Nikon COOLPIX... • Answered on Nov 27, 2014
Green light is off or blinking
check the battery
11/27/2014 9:02:42 AM • Nikon COOLPIX... • Answered on Nov 27, 2014
2answers
How to bring up photos on my computer from camera.
you will need the usb cable to connect your camera to your pc and when you connect them the software should install either automatically or if the camera came with a cd you will need to insert the cd and install the software yourself then when you open the program that was installed it should give you an option to view the photos or to sync them with the pc and if this is not the case when you connect the camera if you open my computer there should be another drive where you see your C: drive
11/27/2014 8:18:38 AM • Nikon COOLPIX... • Answered on Nov 27, 2014
Previously I transfered 196 photos OK probably 2 yrs ago now having trouble Why?
have you formated the card
10/12/2014 4:29:28 AM • Nikon COOLPIX... • Answered on Oct 12, 2014
2answers
Why does the date/time on my L18 keep changing itself
This indicates that the built-in battery of the camera is damaged.(All digital cameras have a tiny built-in battery) Replace that battery and you'll be OK. Don't ask me how to do that change. Get the manufacturer to point you to the location of that built-in battery or put it to a service centre.
9/15/2014 4:14:59 PM • Nikon COOLPIX... • Answered on Sep 15, 2014
Nikon COOLPIX L18 Digital Camera Logo
765 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
received camera few years ago as gift
  • Cameras
