SOURCE: S-Sir Sub Unit won't pair
I almost went out and bought a Sony HDMI cable but I tried something first and it worked me. I wrapped tightly the transceiver on the back of the main unit with aluminum foil and what do you know it fixed the problem. I guess since I was using a cheap HDMI cable the foil helped to shield out the interference. Sony HDMI cable $70.00 or aluminum foil 5 cents. Let me know if this works for you as well.
Brent
mevioradio.com
SOURCE: EZW-RT10 (S-Air) surround speakers not working
Do you need a new pairing of surround. select the pairing menu at the home, turn on the surround and press the button that is below the s-air cartridge. A red light will light the rear surround and make a new pairing.
