20 Most Recent Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Questions & Answers
To connect Home Theatre System+Satellite receiver+TV through HDMI
you are to buy component to HDMI adaptor.
1/26/2018 6:52:44 PM • Sony BRAVIA®... • Answered on Jan 26, 2018
0answers
2answers
I have the same problem as this guy had
Same problem with my 46EX1 but not solved yet...
Have you received an answer of found out this issue ?
Thanks for let me know !
7/18/2017 12:33:08 PM • Sony BRAVIA®... • Answered on Jul 18, 2017
Connect cablebox/dvr to sony bravia
try yellow cable into the green y input. http://en-americas-support.nintendo.com/app/answers/detail/a_id/3008/~/unable-to-locate-a-yellow-video-input-on-the-tv The problem is that av output is going into component in If the green port doesn't work I read on another forum that you may be able to use a dvd recorder unit to take the av in and then it can re transmit the video to an output as component out on some dvd recorders.
4/29/2017 12:35:29 AM • Sony BRAVIA®... • Answered on Apr 29, 2017
3answers
Turn demo mode off on Sony Bravia TV
Press and HOLD (5 sec) the MENU button located on the SIDE of the TV. A message will appear; (Demo Mode: OFF).
4/18/2015 7:11:54 PM • Sony BRAVIA®... • Answered on Apr 18, 2015
Unable to control audio after playing a DVD using HDMI
you may have a damaged remote circit or reciver on the dvd player or tv, look for a phone number on the instructions book to call and see if you can send it in to have it checked out
7/20/2014 4:50:36 PM • Sony BRAVIA®... • Answered on Jul 20, 2014
0answers
2answers
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
4/10/2014 11:15:28 AM • Sony BRAVIA®... • Answered on Apr 10, 2014
Push power protector
If it really says, "Push power protector", there should be a reference to it in your owner's manual. Check there first.
2/10/2014 3:06:35 AM • Sony BRAVIA®... • Answered on Feb 10, 2014
0answers
Factory reset
Be the first to answer 12/17/2013 3:21:24 AM • Sony BRAVIA®... • Posted on Dec 17, 2013Be the first to answer
2answers
I want to control my Sony DAV-HDX576WF with my Comcast remote control and need the remote control code.
Reposting from multiple sources.It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TVicon1.png/VCRs).Then do the following:1. While still on AUX, press and hold SETUP again until the remote blinks twice2. Type 9943. Press and release SETUP4. Type 329755. Press and release VOL+The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:Vol+ = 32975Vol- = 31951Power = 32719Mute = 33743Good luck. Let me know if it works.Also, to program your remote to function volume controls while in CBL or TV mode without switching between modes to change the volume, see below. Source http://www.hifi-remote.com/forums/viewtopic.php?t=8831Quote:Locking Volume Control To TV or AUX Mode: 1. Press and hold SETUP until the Red light flashes twice, then release SETUP. 2. Enter 9 - 9 - 3 (Red light will flash twice). 3. Press and release either TV or AUX (Red light for selected device will flash twice).
10/30/2013 10:34:07 PM • Sony BRAVIA®... • Answered on Oct 30, 2013
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
9/27/2013 2:38:37 AM • Sony BRAVIA®... • Answered on Sep 27, 2013
HOW TO TURN OFF DEMO MODE ON SONY DAV-DZ260
It's a selection in the setup menu.
8/6/2013 8:11:43 PM • Sony BRAVIA®... • Answered on Aug 06, 2013
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
117 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
want control sony dav hdx576wf comcast
  • Audio Players & Recorders
