20 Most Recent Sony STR-DE597 Receiver Questions & Answers
I've had a Sony STR-DE725 for years, and it's always worked fine, until recently. When I turn it on, instantly, or within 1 minute - it will "click" and then display "PROTECTION". Like any good DIY'er, I googled everything - so I looked for any loose speaker wires, and finding none - decided to open it up. I pulled it out on my workbench, opened up the case, and blew out about an inch of dust from everywhere with an air compressor. Next I disconnected and reconnected every connection that I could easily reach. Finally, I unscrewed (about 1/4 turn) and re-tightened every single screw that I could reach in the guts of the receiver. It works fine now! Go figure... probably the dust, or a loose connection somewhere. Definitely try this first, as you have nothing to lose but 30 minutes of your time on a weekend!
Sony STR-DE597... | Answered on Jul 22, 2019
There's nothing more you can do. It is likely a shorted output transistor that became damaged when either playing too loud for too long, connected to shorten speaker wires, etc. A repair shop or replacement will be you best options.
Sony STR-DE597... | Answered on Sep 10, 2015
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Sony STR-DE597... | Answered on Feb 18, 2015
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
The wires to the speakers may be in the wrong positions check and make sure...
Sony STR-DE597... | Answered on Apr 23, 2014
More than one.
Sony STR-DE597... | Answered on Feb 08, 2014
You have a damaged amp. Need to get repaired.
Sony STR-DE597... | Answered on Sep 23, 2013
Sony STR-DE597 Receiver Logo
120 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
after years excellent service
  • Audio Players & Recorders
