20 Most Recent Panasonic Home Theater System System Questions & Answers
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Panasonic Home... | Answered on Apr 20, 2019
How does it manage without speakers?
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Panasonic Home... | Answered on Nov 11, 2018
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Panasonic Home... | Answered on Aug 17, 2017
look inside for blown or deformed capacitors and replace them.
Panasonic Home... | Answered on Aug 16, 2017
Panny dude is full of ----. Just use lower gauge cable for long lengths and take care not to short out the connections
Panasonic Home... | Answered on Jul 22, 2017
Is there anything mentioned about cable accessible via the remote ... assuming you have one that works for the unit?
Panasonic Home... | Answered on Apr 23, 2017
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
Panasonic Home... | Answered on Sep 21, 2016
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Panasonic Home... | Answered on Jul 20, 2016
Check out the Panasonic Website- Most big Japanese manufacturers do this. I hope this helps, they are usually in the Support section.
Panasonic Home... | Answered on Jan 10, 2016
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Panasonic Home... | Answered on Oct 23, 2015
You may have to enter TV menu and see if you have a AUDIO setup option, some TV`s you have to enable TV AUDIO OUTPUT, this cancels the built in tv speakers and engages the AUDIO OUTPUT jacks on the TV
Panasonic Home... | Answered on Apr 11, 2015
Panasonic Home Theater System System Logo
627 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
panasonic sc pt750 home theater system
  • Audio Players & Recorders
