20 Most Recent
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Questions & Answers
Push power protector
Do a cold reset, page 90 of your manual. Push power button, stop button and disk eject at the same time. Wait 5 minutes and turn back on. Look on page 90 of the manual. This worked for me after trying over a year. I beat I didn't have 25 hrs on mine. Good Luck
Protector and "push Power"
Please check speaker wires should be properly connected and not touched / shorted.
Push Power Protect is error sign when unit got problem in Power Amp area and mostly its Power Amp Out IC failure.
I would suggest to ask Sony for warranty cover.
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
I need device codes
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Code for Comcast remote for Sony DAVHDX275
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Not all my speakers sound
Most inputs are not true 5.1 surround; with the exception of the mic and many movies. You will not have all of them working from, say an ipod or TV unless you choose a sound mode that mimics 5.1 or grater from a 2.1 source. These are modes like Pro Logic (1&2) and often "entertainment mode" or something simmilar that plays the sound out of all 6 channels.
How do connect my speakers so that i can hear them
To hear the TV system through your Sony unit you will need to connect a RCA type lead from the AUDIO OUT sockets on the back of your TV to the AUDIO IN sockets on the back of the Sony unit. These types of leads are readily available in lots of stores and usually have a red, white and yellow connector on each end. You will only need to connect the red and yellow leads and they should be clearly marked on both units.
You will also need to set your SONY unit to AUX mode but you will not get proper Surround Sound.
Why do my tv screen appears in three sections when
hi,
check is your tv supports progressive scan, if not switch off the progressive scan mode on your sony home theater system.
For switching off the progressive scan mode do the following in ur home theater's remote.
Do this setting if your connected the component video
1. Press the FUNCTION BUTTON on the remote.
2.Press the VIDEO FORMATE button to select interlace scanning.
If you are connected the HDMI then do the following setting
2.Press the VIDEO FORMATE button to select the resolution
Select 720 * 480p
