Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Posted on Aug 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY SONY TV WAS WORKING PERFECT UNTILL WE MOVED IT, NOW IT HAS NO SOUND OR PICTURE, JUST CONTINUING RED LITE BLINKING IT IS MODEL NUMBER SONY WEGA TRINITRON KV36FV15 BLINKING IS CONTINUING NO STOPPING UNLESS I TURN SET OFF
Anonymous
Level 2:
  • Expert 125 Answers
  • Posted on Aug 06, 2008
Anonymous
Expert
Level 2:
Answers
125
Questions
Helped
22095
Points
213
How many blinks do you see or count on the red led
Turn on tv no picture no sound standby light starts green changes to flashing red
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
4helpful
2answers
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
2answers
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
1helpful
Have a sony kd32fs130 and after limited viewing the picture goes out. I still continue to have sound but no picture and the red light blinks. Which part I need to change?
How many times red light blinks when TV lost picture? There would be interval of 3 seconds in red light blinks so count pause to pause and let me know.
Sony 34 No picture or sound the standby lite just keeps blinking.
Does the ligh blink a certain number of times and the stop briefly and repeat the same pattern? If so you have a problem that is beyond your ability to service it and must be serviced by a certified sony tech.
1helpful
My sony kd32fs130 red light blinks 5 times
your video circuit is not working that is why you are not getting picture
1helpful
2answers
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
6helpful
4answers
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
