20 Most Recent
Sony FD Trinitron WEGA KD-32FS130 32" TV Questions & Answers
Will not turn on.
if the power indicator light is not blinking, there is a problem in the main power supply.if it is blinking 2 times there is a short (SOMEWHERE)somewhere takes in a lot of territory, and the FBT would be included in that. If it is the flyback, it WAS over $100, but is no longer available from SONY
3/19/2013 4:47:56 AM •
Sony FD...
Answered
on Mar 19, 2013
Turns off by itself
Looks like SMPS problem. Check the power supply circuits for any leakage or short. SMPS will shut down for any fault condition in the circuit. After checking finally check opto isolator in SMPS and replace with new ones.
DO NOT SWITCH ON TV if OPTO I C is removed. SMPS will go out of control and the power supply capacitors will explode due to raise in voltage!
7/9/2010 6:09:26 AM •
Sony FD...
Answered
on Jul 09, 2010
My son stepped on a remote control for a DVR. The
It is possible that the button your son stepped on is stuck. If so, remove the batteries form the DVR remote control and see if the TV works. Unplug the TV from the wall for a few minutes to clear its memory to be sure. Some times remote controllers can have cross-talk, meaning it can affect other equipment,
12/27/2009 11:32:23 PM •
Sony FD...
Answered
on Dec 27, 2009
Tuning digital channels
This is answered on the sony support pages see
http://www.sony.co.uk/section/contactand then enter 're-tune digital channels' in the 'search by keyword' box for the explanation.
It basically needs a software upgrade which will be downloaded free if you've still got a freeview channel - but if you've lost them all you'll need help - anyway it's all explained by sony.
11/7/2009 5:51:47 PM •
Sony FD...
Answered
on Nov 07, 2009
WILL NOT RETUNE CANNOT FIND INSTRUCTION BOOK
The retuning process is as follows:
- Press the [i+] button on the remote control to display the DIGITAL INFO menu.
- Press the BLUE button to display the MAIN MENU.
- Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
- Press the RED button to start the auto tuning process for all available digital channels.
- Wait for the process to complete.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
10/3/2009 12:33:14 PM •
Sony FD...
Answered
on Oct 03, 2009
Have a sony kd32fs130
How many times red light blinks when TV lost picture? There would be interval of 3 seconds in red light blinks so count pause to pause and let me know.
6/12/2009 1:11:37 AM •
Sony FD...
Answered
on Jun 12, 2009
Sony WEGA KD-32DX50 U Tuning problem
http://www.sony.co.uk/section/contactand then enter 're-tune digital channels' in the search by keyword box for the explanation.
3/26/2009 10:20:42 AM •
Sony FD...
Answered
on Mar 26, 2009
The screen
Hi
you have defective Horizontal linear! or defective deflection yoke! this need to replace the yoke!
Thanks!
12/27/2008 1:18:28 AM •
Sony FD...
Answered
on Dec 27, 2008
Stuttering Start Up....
This tv do loose connections on power supply or horizontal area. Some time bad capacitors in power supply. Maybe just need be resolder connections. Or try to find electronic cooler spray in use on power supply area , you will see changes on you original problem.
5/11/2008 1:43:21 PM •
Sony FD...
Answered
on May 11, 2008
32 inch sony wega
power board problem, needs to be repaired or replaced. Any TV tech can do this with the proper replacement parts. Common.
3/3/2008 6:19:35 PM •
Sony FD...
Answered
on Mar 03, 2008
Poor sound quality
This is just a guess but the dolby sound on my system is bad however when I switch to regular "stereo" sound it improves. See if your audio set up has a choice of sound and try them all.
12/27/2007 2:06:33 PM •
Sony FD...
Answered
on Dec 27, 2007
