20 Most Recent Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Questions & Answers
When was the last time u replaced the lamp?
Sony Grand WEGA... | Answered on Dec 31, 2018
The problem is the light engine, the coded lens blue filter is burned out. It can't be cleaned. You may search on Google or EBay to find a replacement engine, it usually cost $400.00 to $600.00 to get one.
Sony Grand WEGA... | Answered on Jan 15, 2018
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
Sony Grand WEGA... | Answered on Aug 04, 2017
Where did you buy your lamp? sounds like its not a real philips or osram. Discount merchants sells some junk lamps. If you got it there, thats your problem
Sony Grand WEGA... | Answered on Sep 30, 2016
Consumer Electronics Control (CEC) What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions? Submit a request
Related articles
Sony Grand WEGA... | Answered on Jun 14, 2015
Cleaning the optics won't hurt as it removed build up off of mirror . but I'd suspect the bulb is nearing the end of its life cycle . or a light engine failing .
Sony Grand WEGA... | Answered on Apr 08, 2015
you will need to replace the lamp
part# A-1606-034-B
see the following web site:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KDF-50WE655
Sony Grand WEGA... | Answered on Mar 04, 2015
i have a sony sxrd and it shows 5 blinking lights on red
Sony Grand WEGA... | Answered on Sep 28, 2014
to change a ballast board its a bit of work and a tear down to get it in there . but first lets review your problem .
its cycling off every 30 seconds . id suspect a defective lamp or a power supply problem since it sounds as if the ballast board does fire . that's assuming that you do see something come up on the screen when it attempts to start if a ballast has failed it usually will make a noise or the set would almost go into a shut down . also how many blinks and what order are the events happening ?
Sony Grand WEGA... | Answered on Jun 22, 2014
hello
i would suspect the IR sensor in the Tv set it self.
Sony Grand WEGA... | Answered on May 08, 2014
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
591 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
remote will not work
  • Televison & Video
