20 Most Recent
Sony FD Trinitron WEGA KV-36HS510 36" TV Questions & Answers
Hi, I'm using a Sony
If your TV connected through stabiliser, disconnect stabiliser , connect TV directly to plug socket. and check up.If TV works your stabiliser is defective.
12/18/2017 5:57:30 AM •
Sony FD...
Answered
on Dec 18, 2017
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
5/17/2016 10:42:44 PM •
Sony FD...
Answered
on May 17, 2016
No picture only sound
that problem smetimes in the heater of crt check filament small amount of light if not maybe risistor of the heater is open or loose look for it
1/22/2014 2:29:05 AM •
Sony FD...
Answered
on Jan 22, 2014
No picture only sounds
look for loose connection in high voltage or horizontal section ,resolder jungle ic
1/22/2014 2:03:09 AM •
Sony FD...
Answered
on Jan 22, 2014
Sony manuals
http://remotes.com/
You can with a good universal remote control that have the feature in it. But above the webpage to get your own original remote control for your tv. Good luck
12/18/2013 2:44:36 AM •
Sony FD...
Answered
on Dec 18, 2013
Stand by light blinks 6 times, wont power on
Here you find sony blinking codesSIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
9/24/2013 4:50:36 PM •
Sony FD...
Answered
on Sep 24, 2013
Sony wont turn on but will blink in stanby
How many times do this standby light blinks? Count it. These are blinking codes, and are fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. To get more information about blinking codes, check this site. It has details to many brand TVs' blinking codes, including Sony.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option.
9/9/2013 3:09:55 PM •
Sony FD...
Answered
on Sep 09, 2013
TV TURNS OFF ON ITS OWN
11 blinks won't occur to this TV. It might be 10 blinks. If so
Check
Q8014 and Q8013 for shorts, leakage, or bad solder connections on the "
D" board. If the transistors are bad, check R8051 and IC8005, also on the
"D" board.If you want more details about the blinking codes to Sony TVs, check this site.
1/18/2013 5:04:56 PM •
Sony FD...
Answered
on Jan 18, 2013
Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
11/5/2012 12:05:06 AM •
Sony FD...
Answered
on Nov 05, 2012
