The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
This sounds like an internal memory problem and I don't have a workaround. Before you give up, try this technique to reset the printer to factory. They are great printers once you learn this reset technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
The alarm is just a coincidence i suspect, green light comes on and stays on probably not the battery at fault. It would be red. If the green light goes out and screens just flash one of your screens are at fault or a loose ribbon connection.
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
This was not the sollution for my pinter.. My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the resume/Cancel button. (DO NOT release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) 4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped. 1 time Orange (Alarm) Service test print . 2 times Green (Power) EEPROM information print 3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE 4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see "Destination settings procedures" below. 6 times Green (Power) Print head deep cleaning (Cleaning of both black and color) 7 times Orange (Alarm) Reserved 8 times Green (Power) CD / DVD check pattern 9 times Orange (Alarm) CD / DVD print position correction (horizontal: X direction) 10 times Green (Power) CD / DVD print position correction (vertical: Y direction) 11 to 13 times Orange, Green, Orange(Alarm, Power,Alarm) Return to the menu selection 14 times Green (Power) Left margin correction Not used
in servicing. 15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print 0 times Green (Power) No change of the destination 1 time Orange (Alarm) Japan Supported 2 times Green (Power) Korea Not supported 3 times Orange (Alarm) US Not supported 4 times Green (Power) Europe Supported 5 times Orange (Alarm) Australia Supported
