20 Most Recent HP Pavilion dv4000 Notebook Questions & Answers
3answers
My internet connection keeps dropping every 2 minutes!!
That particular series of HP computers has a recall with an extended warranty for just this problem. Call HP, they will have you go through all the first line cures but tell them you know of the extended warranty for lost wireless problems. They'll replace the mother board. Make sure you back up all your data when you send it in. I've sent them nearly a dozen and some they reformatted the hard drives.
6/7/2022 1:57:35 PM • HP Pavilion... • Answered on Jun 07, 2022
2answers
Download a vga.dll 5.01.2600.0000
http://www.topshareware.com/vga.dll-5.01.2600.0000-video-driver/downloads/1.htm
There you are.
6/18/2019 3:56:40 PM • HP Pavilion... • Answered on Jun 18, 2019
3answers
Can you reset your computer back to factory setup
1) connect to external monitor to see if it works. If it doesn't work, then its a video card on the motherboard issue. 2) If connect to external monitor works, then its the screen or screen connection on the laptop.
6/7/2019 1:34:18 AM • HP Pavilion... • Answered on Jun 07, 2019
2answers
I would like to get a wireless headphone to listen to the radio.
its no wireless its bluetooth i guess,, correct me if im wrong
6/18/2018 8:32:44 PM • HP Pavilion... • Answered on Jun 18, 2018
2answers
Hp pavilion dv4 laptop is
first off there is no such thing as a DV4, sorry!!!! dv4-1000, 1280,1300, right?,. it's 10 old, the battery is that old is no good, the dash matters too if present (details do) or is it a DV4000, 13 years old not 10 .??? why not post the full model and p/n off your PC service tag so i can show you matching manuals to read and follow, ok? THE AGE MATTERS AS DOES REAL MODEL NUMBERS!!! that is blink code, try to learn how to read them , counts them. here is a list of tests, simple. to harder. 1; Remove that old big battery 10 years old , it shorted. 2: run on AC power only. in fact can do this forever....... 3: next is the fan working? fan is next and now, does it? 4: flash codes, count them and report them, easy no? 5: the coin cell is next , it is 10 years old that too is END OF LIFE why not replace it too ,now even if good, to avoid problems later, ? My answers are for DV4000 only not the DV4-1000 and up vast series of laptops. vast versions of them... the coin cell , HP name RTC battery, all die at 5-7 years old. yours is well beyond that. ok? lets do chapter 5 covering just that now. here it is, pg 5-20 pdf page 126 we take it it out if lower than 2.9v (a dmm meter is cheap) we replace it, 3.3 is normal when the fall to 2.9 (think cliff) they fail fast and the BIOS GOES NUTS, in fact the PC can be totally dead. see the manual , if wrong next time tell full service tag data.!!! https://www.manualslib.com/download/71706/Hp-Pavilion-Dv4200.html dv4000-k5q5be0wp0wngr0s3gry320h-1-0.jpg that caps lock flashing are codes, learn to count them my wild guess is it is the code for BIOS NVRAM corruption. the cure is posted here over 1000 times. and a million times at HP.com real, we are not HP.
2/26/2018 2:58:58 PM • HP Pavilion... • Answered on Feb 26, 2018
2answers
I have a HP Pavilion
Usually this means u have a damaged led panel or panel ribbon connector try a new LED screen first try ordering from Amazon get the numbers off the back of the screen
1/23/2018 10:34:24 PM • HP Pavilion... • Answered on Jan 23, 2018
3answers
Cant get internet connection
Web page doesn't show images, getting red x's, or broken links. When browsing the Internet, a number of different issues can occur with your ... verify that your Internet connection is working and images are not loading.
Internet questions and answers. CH000539, How do I determine the speed of my Internet connection? ... CH000804, Where can I get Internet access when away from my home or work?
My computer is running slow what steps can I do to fix it? If your Internet is slow this document does not contain information about ... for additional information about why your Internet connection may be slow.
Read & follow Instructions /Please dont for get to Vote/Thank You.
11/28/2017 12:39:03 PM • HP Pavilion... • Answered on Nov 28, 2017
Quick touch
got nothing?, (means PC is dead or just key buttons dead) tell what works and not, we can not watch you or it. please Series: DV4000 is a series of LT. it has a full & real model stated on its service tag, only THAT works, so how'd it get w8? there? (bought FROM MS or HP?????) why mess with BIOS> ? if this fails it bricks the PC. (if you must flash always flash using the usb stick way. (freedos) not only that using the wrong model to flash, HP sold this series with AMD and Intel processors. oops...... next time before doing such big thing ask, hp first? both model and p/n matter, when doing updates or buying parts. big time! tag1-nvn5fnzys0y3nze0x40aj1l2-5-0.jpg learn that HP page, the exact model and OS must be selected or it shows you the WRONG BIOS and wrong driver and wrong HP APPS. for a fact. here is the series page, dangerous, imo https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv4-4000-entertainment-notebook-pc-series/5082208 use the real page by using real models # BIOS101 pick any LT. even yours. the PC can have 6 different network chips used in the long production run.. and GPU and other features, very different. in your case even the CPU vastly different. amd/intel so giving that fact, picking the right BIOS binary can be very hard. best of all why not ask HP before even walking the path. https://h30434.www3.hp.com/
7/28/2017 1:07:15 PM • HP Pavilion... • Answered on Jul 28, 2017
2answers
Windows operating system
you can make a dual book (multi OS) on your laptop so that you can just switch over to XP or vista and vice versa.
try this article on MS on how to install a multi OS. i haven't tested it in vista though...but i think it would work..please let me know.
also..you can use a Virtual PC and install XP there, its much more easier.
5/31/2016 3:47:15 AM • HP Pavilion... • Answered on May 31, 2016
Forgot password and how to unlock
If this is a windows computer, you can look online for a program to erase your current windows password. I found one called Offline Windows Password & Registry Editor. I had to 1. download the program onto a second computer that I could logon to, 2. Burn the program to a DVD or USB stick 3. Go back to the computer I forgot my password on, and turn it off/on 4. As it is turning on, press the F?? key that the screen says to go to the boot menu. 5. Tell your computer to boot to the DVD or USB stick 6. Follow the instructions included with the software to reset your password to blank. Note: Remember what account you login with, so you reset only that account's password. 7. You should be able to reboot your computer, and login without a password.
5/8/2015 2:13:08 AM • HP Pavilion... • Answered on May 08, 2015
Hp load h4
need more info
4/15/2015 9:38:23 PM • HP Pavilion... • Answered on Apr 15, 2015
My asdfkl and enter buttons in HP Pavilion dv2000 are not working
you may need to replace the keypad or try cleaning under the keys.
4/13/2015 2:18:02 PM • HP Pavilion... • Answered on Apr 13, 2015
How to increase volume aspire 57386969
Generally laptop speakers aren't that loud, plug in an external speaker into the headphone jack for higher volume. Bottom right of the screen should have a speaker icon to change the volume.
4/5/2015 6:34:47 PM • HP Pavilion... • Answered on Apr 05, 2015
Hp g6 series mouse pad not working
You may have temporarily turned it off by accident. See the image below, if not reply and I can suggest other things. 24803624-wsjhsfa5vjycjgfazcdhels3-5-0.png
4/5/2015 6:00:31 PM • HP Pavilion... • Answered on Apr 05, 2015
2answers
I am facing no audio output for hp pavilion dv4000 laptop with windows 7 ultimate
While online, Right click on my computer then go to device mangers click go to audio devices right click then go to update device driver or update driver
3/29/2015 7:14:22 PM • HP Pavilion... • Answered on Mar 29, 2015
Vista downgrade to xp
First, why are you downgrading? Unless you have a particular piece of software that you HAVE to have that doesn't work on Vista, you shouldn't downgrade. Windows XP is outdated, and very soon won't be supported by Microsoft. So unless you have some overwhelming need to have outdated software stick with Vista.
Having said that... If you still want to go ahead with a downgrade to XP, first you'll need a copy of Windows XP and a serial number for XP.
(Note, everything on your computer WILL be erased so make sure you do your backups before you continue!!!)
1) Put the Windows XP CD in your computer and restart it. If your computer is set up to boot from CD, it should start automatically.
2) "To setup windows XP now press enter"
3) Agree to the licensing agreement
4) Choose whichever drive you want to install Windows on and press enter
5) Choose "Format the partition (Quick) and press enter
6) Press "f" to format the drive
7) It'll do the install then after a reboot it should show Regional Option, click next
8) Put your name in and click "Next"
9) Enter your 25 digit product key (Windows XP Key) and click next
10) Enter whatever you want for your computer name. It could be "Desktop" or "Laptop" or "Family System" whatever you like. If you're installing XP Professional, you'll also see a spot to type in a password to get into windows. You can leave it blank if you're the only one using it, or password protect it so no one can get in. (Then Press Next)
11) Make sure your Date/Time and Timezone is correct then press Next
12) "Typical Settings" next.
13) (IF XP PRO) Choose "No" then type in WORKGROUP
14) It should start windows after you've done those steps and you can register with Microsoft and create additional users at this point (All self-explainitory).
You might want to print this out if you're going to go ahead with the install.
3/20/2015 9:29:37 AM • HP Pavilion... • Answered on Mar 20, 2015
Hewlett Packard HP Pavilion dv4 back door
If you want to reset the BIOS password remove the computers battery and then open the backpanel and remove the bios battery for about 20sec. If you want to reset Windows admin password this is harder issue -> easy way make a backup and reinstall windows and then restore the backup.
1/28/2015 12:16:36 PM • HP Pavilion... • Answered on Jan 28, 2015
How do I rest a hppavilion dv4000
Either the computer came with a recovery disc, or during the boot up at the HP screen thre should be some options. Typically F11 will get you into a recovery partition which should allow you to re-install Windows. This will wipe out any data you have.
1/19/2015 2:20:23 AM • HP Pavilion... • Answered on Jan 19, 2015
My hp notebook wireless net is not stable on my machine
It could be your wireless card which you can replace through the bottom of the machine. Take it out and get the part number and do a search on amazon for it. It should be fairly inexpensive $5-10 I'm guessing. If that doesn't work I would just get a USB wireless adapter which you can also get from amazon. Good Luck! ROCKSolid Computer Services Livonia NY Rockhopper Technologies
12/12/2014 6:33:45 PM • HP Pavilion... • Answered on Dec 12, 2014
3answers
MS-7184 motherboard drivers
Here is the link to all the support and drivers for this board by HP:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1127366&lang=en
10/13/2014 4:31:23 AM • HP Pavilion... • Answered on Oct 13, 2014
HP Pavilion dv4000 Notebook Logo
1,229 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
hewlett packard hp pavilion dv4 back
  • Computers & Internet
