20 Most Recent Sony KDF-E60A20 60 in. LCD HDTV Questions & Answers
Heating thermostate is not working
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ I haven't ever heard about a "Heating thermostate" with no TV.
3/13/2016 6:21:11 AM • Sony KDF-E60A20... • Answered on Mar 13, 2016
When i turn my sony 60inch projection tv on it
I WOULD LIKE TO KNOW, IF SOME OF THE LIGHTS FLASHE WHEN SHUTS OFF ITSEL..PLEASE GIVE MORE DETAILS...THANK YOU.
4/5/2015 6:28:55 PM • Sony KDF-E60A20... • Answered on Apr 05, 2015
My Sony TV made a pop noise followed by a odor, when we turned back on no picture but there was an intermittent rattle noise, help?
Theres a few moving parts inside the TV. Sounds like it could be the color wheel or one of the fans.
3/7/2015 12:15:26 AM • Sony KDF-E60A20... • Answered on Mar 07, 2015
2answers
Thermal fuse replacement
sony part# 191002393. try mcm electronics on the web.
12/16/2014 5:06:34 PM • Sony KDF-E60A20... • Answered on Dec 16, 2014
Video Input Display Will Not Go Away
Its Normal operation of Onscreen Display.
11/2/2014 6:50:19 PM • Sony KDF-E60A20... • Answered on Nov 02, 2014
Tv blinks 6 red blinks
Thermal Fuse kit needs replacement = part # 1-910-023-93
Qualified tech only.....T.
8/18/2014 4:33:10 AM • Sony KDF-E60A20... • Answered on Aug 18, 2014
How to install cable card
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
7/27/2014 4:34:29 AM • Sony KDF-E60A20... • Answered on Jul 27, 2014
Where can you get a replacement cooling fan? There is a link you have on another question but it gives me an error message.
cooling fans can be bought at any electronic parts supply house, all you need is its measurements and voltage type and voltage level, ex: 25x25x10 110v ac. 25mm long 25mm wide 10mm thick 110 volts and ac voltage. most of the newer fans are measured metric but not all. ebay also has a tremendous number of fans available, that is where i have gotten the last few iv'e needed. good luck.
6/29/2014 1:39:16 AM • Sony KDF-E60A20... • Answered on Jun 29, 2014
I cant access Netflex and when I try to access Netfles it shuts down TV
It could be the dns settings
What are you using to access Netflix laptop console phone pc
In any case try uninstalling Netflix then reinstall
If you ate using a game console try going to internet settings clear the settings and reconnect this should put all settings back to default You should now have Netflix enjoy
4/30/2014 12:15:32 AM • Sony KDF-E60A20... • Answered on Apr 30, 2014
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
4/26/2014 9:32:52 PM • Sony KDF-E60A20... • Answered on Apr 26, 2014
Blinking 21 times power red LED
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience
4/2/2014 7:22:28 AM • Sony KDF-E60A20... • Answered on Apr 02, 2014
3answers
Sony KDL-46V3000 Bravia LCD Black screen
It's not to complicated, in the newer TVs as well as other things, when you first turn them on the diagnostic circuits kick in [that the first relay you hear click] it sends a signal (low voltage) to all the circuits to check them and make sure there are no problems. If it gets the proper returns from each circuit it kicks out and the full power relay kicks in and powers your set up. This is done to protect others circuits that might be effected by a flaw in a different circuit. What started as a small flaw in a component has gotten worse with use which is normal. Your set is kicking the diagnostic circuits and they are detecting the problem and shutting it down. You have problems with your power board, if the diagnostics circuits were not in place and full power hit the set the power board could possibly put triple or more voltage to some section of another board, thus burning it out also. That's why they started using the diagnostic circuits on TVs, Computers have had them for years. Late model car - etc. I would take the power board out of it and go to shop Jimmy's and enter the part # which will be on the board and order me another one and pop it in and kick back and watch TV again. I don't know what a power board would cost for it but "shopjimmy's" carries high quality boards at a reasonable price. I do caution you on buying a refurbished board, they are tempting but I have never and I mean never seen one hold up very long. As a matter of fact I will not put one into a TV or anything else for that matter. So there is light at the end of the tunnel and it's not the train this time! I only work on the kind of TV that plug into the wall or run on batteries, therefore, I've seen a bunch of them in14 years. Don't worry about getting the wires mixed up because one thing about TVs is a harness or plug will only fit one place and that is where it belogs you can't cross them up.Gillight
4/2/2014 6:47:14 AM • Sony KDF-E60A20... • Answered on Apr 02, 2014
TV will not power up, no blinking lamp
hi caps don't have to be swollen to be fault that blinking light means you have no 5 volt standby, you need to check diodes capacitors transistors resistors may be best to look for a tech in your area, hope you get it working regards shaun
1/26/2014 7:51:39 AM • Sony KDF-E60A20... • Answered on Jan 26, 2014
Red lamp indicator light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/11/2013 5:18:30 AM • Sony KDF-E60A20... • Answered on Nov 11, 2013
Sony bravia kdl46ex500. red led light is blinking
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/5/2013 9:17:24 AM • Sony KDF-E60A20... • Answered on Nov 05, 2013
Sony KDF-E60A20 60 in. LCD HDTV Logo
362 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
heard pop noise followed odour when
  • Televison & Video
