20 Most Recent HP Pavilion dv2000t Notebook Questions & Answers
24answers
HP Pavilion dv 2000 Won't start up at all!
HP has an extended warranty service for these laptops.
CHECK YOUR # AGAINST THIS LIST
2/9/2021 11:38:35 AM • HP Pavilion... • Answered on Feb 09, 2021
2answers
I have an australian HP Pavilion dv2000 laptop and
There are multiple ways but the easiest for most is to install and run dvd genie
You can get it HERE.
It's free.
Hope this helps.
5/21/2020 7:04:33 AM • HP Pavilion... • Answered on May 21, 2020
2answers
Hi, i have a pavilion
If posts and two beeps it is a memory issue. If it is not posting there may be a corrupt cmos. If not that, you might have a bad hard drive, corrupt OS, bad peripheral. If you have an xp install disk you can attempt a OS repair operation Good luck - you have your work cut out for you.
9/7/2017 11:53:58 AM • HP Pavilion... • Answered on Sep 07, 2017
Power black screen failure hp pavillion dv2000
Normally is because the battery is empty or in an error state. If you plug the power cord and the led still blinking, disconect everything, turn your laptop and search how to take out the battery, wait 1 minute then replug it again and try.
5/18/2016 9:17:42 PM • HP Pavilion... • Answered on May 18, 2016
What is f8 key
F8. It can perform several functions, and does not have an assigned windows default. However, when starting Windows 2000 or Windows XP, holding the F8 will boot in safe mode. Function key Wikipedia the free encyclopedia
11/22/2015 10:25:07 AM • HP Pavilion... • Answered on Nov 22, 2015
Laptop screen was divided into 6 small parts
have the same problem. if updating the graphics driver doesnt work then it probably is the same as my problem.
HP service center said it's the graphics card or video card but since the video card is embedded in the motherboard, then you will have to replace the motherboard.
11/7/2015 2:43:04 PM • HP Pavilion... • Answered on Nov 07, 2015
2answers
Blank display on HP dv2000 laptop
i suggest you dismantle your laptop and take a look at the LCD cable behind the screen and make sure it is click locked.
9/11/2015 2:36:34 PM • HP Pavilion... • Answered on Sep 11, 2015
2answers
I have an HP Pavilion dv2000 and i dont know how to open webcam.
I have an HP Laptop with the webcam. Here is info on it.
There should be an icon on the desktop that you can double click to activate it. Then if it is activated the blue light will go on next to the webcam. If there is no icon do the following:
If the webcam icon is not on the desktop, click Start , click All Programs , select HP Pavilion Webcam to open the webcam from the Windows Start menu.
    • Select HP Pavilion Webcam Demo for a demonstration of the features.
    • Select HP Pavilion Webcam to open the webcam window and display an image from the webcam
  1. If the webcam icon is not on the desktop or on the Windows Start menu, click Start , and My Computer to open the My Computer window. The webcam should be listed under the Scanner and Cameras heading. Double click on the icon to open the webcam window and display an image from the webcam.
  2. If the webcam icon is not displayed on either the desktop or the My Computer window, or cannot be started from the Windows Start menu, the webcam is either disabled or the drivers are not installed.
Enable the webcam If the webcam icon is not displayed on either the desktop or the My Computer window, or cannot be started from the Windows Start menu, the webcam may be disabled. To enable the webcam, do the following actions.
  1. Click Start , right-click My Computer , and then select Properties .
  2. On the My Computer properties window, click on the Hardware tab, and then click Device Manager .
  3. Click on the plus ( + ) sign next to Imaging Devices and locate the webcam item in the device list.
  4. If the webcam is listed under Imaging Devices but there is a red X on the c00678428.gif icon, the webcam is disabled. To enable the webcam, right-click the HP WebCam 1000 icon and click Enable . The webcam icon should now display on the Desktop or the My Computer window.
  5. If the webcam is not listed in the Device Manager window, you should install the original webcam drivers.
If you need the drivers see below.
  1. Install the original webcam drivers If the webcam is not listed in the Device Manager window, do the following activities to install the original webcam drivers using the HP System Recovery.
    1. Click Start , click All Programs , click System Recovery , and then click Application and Driver Recovery .
    2. On the Application and Driver Recovery window, select Driver installation and click Next .
    3. Select HP Pavilion Webcam from the list, and click Install .
    4. When prompted that the installation is complete, click OK .
    5. Allow the PC to restart and test the operation of the webcam.
    When the webcam is operating, visit to the HP web site to look for and install the latest updated webcam drivers. If the quality of the image is not acceptable, you can perform a functional diagnostic test of the webcam.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
6/25/2015 6:28:44 AM • HP Pavilion... • Answered on Jun 25, 2015
3answers
I want download the xp
Download windows xp drivers for hp dv2000 notebook.... HP Pavilion dv2000 laptop Audio, Lan, Chipset Drivers For Win XP
2/15/2015 5:53:57 PM • HP Pavilion... • Answered on Feb 15, 2015
What will i do i activated wrong partition laptop wont boot
only option is factory restoring it
9/4/2014 2:02:40 AM • HP Pavilion... • Answered on Sep 04, 2014
2answers
Dropped laptop, color on screen not natural
The problem could be that you jolted a heat sync or fan loose that cools the video adapter. If you power off the machine and let it sit for several minutes and then reboot and the same thing happens, its a heat issue. Laptops have the graphics card in a chip form soldered to the motherboard, thats not the issue. Undoubtedly you have jostled something loose. If in fact it is a heat issue, you can have someone take the laptop apart and reseat the heat sync or maybe check on the fan that cools the video adapter.
5/26/2014 5:00:53 PM • HP Pavilion... • Answered on May 26, 2014
My HP Pavilion DV2000 Laptop does not get ON.Total
did you try without battery, if yes then check the bios battery and ram if they are ok then its means there is some prob with your motherboard
5/23/2014 12:15:15 PM • HP Pavilion... • Answered on May 23, 2014
Need passwords for fingerswipe
Just in case you can not login using the fingerprint (for example, your finger get paper cut), then you have to use the password, otherwise you can not login. If you need a Windows password removal service, then you can call local computer tech to remove the Windows password. It cost $25 - $50 to remove a Windows password.
2/18/2014 4:33:58 AM • HP Pavilion... • Answered on Feb 18, 2014
Finger swipe
With the HP finger wipe access, it retains your original typed password as a different user. Have you tried changing users and entering that password ??
2/16/2014 9:05:12 PM • HP Pavilion... • Answered on Feb 16, 2014
Hp pavillion dv2700 is not starting, 3 beeps, 1 long and 2 short
That is some sort of video failure. "Unable to initialize video (to display the post code)"
12/31/2013 11:57:59 AM • HP Pavilion... • Answered on Dec 31, 2013
I forget my password and my computer is laptop hp
Please try each of the following: 'kxjgx' 'klwimn' '9789999' '5447994' '66154' '1731146' '494616' and let me know whether or not they worked.
12/17/2013 5:45:21 PM • HP Pavilion... • Answered on Dec 17, 2013
Dell laptop screen is divided into 6 small parts.
Hello, that is a graphic problem, you need to take the laptop to a repair shop to repair it.
11/25/2013 10:10:15 AM • HP Pavilion... • Answered on Nov 25, 2013
I want you to show me how to formant
Hello, format your laptop you need an operating system disk to do it.
11/25/2013 10:04:20 AM • HP Pavilion... • Answered on Nov 25, 2013
0answers
HP Pavilion dv2000t Notebook Logo
580 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
want download xp
  • Computers & Internet
