20 Most Recent HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Questions & Answers
May you explain a bit more you've done? Was this your system disk?
Regards
Stephan
HP PAVILION... | Answered on Jul 31, 2017
Please use the provided USB cable and connect it to an available USB port on the laptop.
If you intend to boot up using the Portable USB DVD Drive - please select the appropriate option under the BIOS settings.
HP PAVILION... | Answered on Mar 06, 2015
Hi
The details below assume that you are using Internet Explorer.
Load Internet Explorer, click on tools and then Internet Options.
In the window that comes up about two-thirds of the way down it says Browsing History. Click the Delete button and the list of options will come. Put a tick in the boxes opposite the options you want to use and click OK. Those options will be applied. There is also an option box for "Delete Browsing History on exit". If you click on this box then every time you leave Internet Explorer your browsing history will be deleted. I give below a picture of the two windows in which you can make the adjustments. 25280385-xgakn3uof1urgwv343232ikl-3-0.jpg
Hope this helps
HP PAVILION... | Answered on Nov 12, 2014
Try these -
1. Turn on your HP Pavilion Slimline computer.
2. Press "F2." This attempts to load your HP BIOS. You are prompted to enter a password.
3. Type "merlin" into the password prompt and press "Enter" to unlock the password on your HP Pavilion Slimline BIOS.
HP PAVILION... | Answered on Jun 26, 2014
This website is not intended to provide product keys. It is against its terms of use and considered pirating.
HP PAVILION... | Answered on Oct 19, 2013
When you install your Windows operating system, it will give you the option to format, also, you can download "Killdisk" and burn it to a cd.
HP PAVILION... | Answered on Sep 29, 2013
It sounds like one of your memory cards are either loose or bad.
Have you connected any other USB devices that could be draining power? Try to disconnect everything but your mouse and keyboard and see if the problem comes back, if this rectifies the issue get a powered USB hub to connect the rest of your devices.
Also check that the USB bandwidth and power level limits are not being exceeded, I have attached a picture
HP PAVILION... | Answered on Oct 05, 2012
But win7 boot? That's normal.
HP PAVILION... | Answered on Aug 09, 2012
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps you
HP PAVILION... | Answered on Mar 20, 2012
Hello Robert.
Can you please let me know the operating system of this pc. Is it Windows xp?
Thank you.
HP PAVILION... | Answered on Sep 29, 2011
looks like this unit is going for $250-$399 on the web......
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
HP PAVILION... | Answered on Jun 28, 2011
Go to HP website and download manual.
HP PAVILION... | Answered on Nov 23, 2010
If you have the operating systems disk boot to the disk like you are going to reload operating system ( OS disk example Window XP or Vista Disk) Run though the steps on screen till you get to the point where it asks if you want to load a fresh copy of OS, this will be past the point where you press F8 to continue. Do not load fresh copy of OS. There should be an option to repare you OS. This will fix the OS with out loosing any of you files and stuff on the PC.
HP PAVILION... | Answered on Sep 17, 2010
it happens u reinstall ur os as soon as u install do not install any other drivers first u install sound drivers later after 1 restart u install other drivers it works
HP PAVILION... | Answered on Aug 31, 2010
<span class="apple-style-span"><span style="font-size:10.0pt; line-height:115%;font-family:&quot;Trebuchet MS&quot;,&quot;sans-serif&quot;;color:black">Open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.</span></span><span style="font-size:10.0pt;line-height:115%;font-family:&quot;Trebuchet MS&quot;,&quot;sans-serif&quot;; color:black"><br /> <br /> <br /> <span class="apple-style-span">You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.</span><br /> <span class="apple-style-span">Hope this helps, </span><br /> <span class="apple-style-span">www.PuterCare.com</span></span><b style="mso-bidi-font-weight:normal"></b><br />
HP PAVILION... | Answered on Aug 30, 2010
try using a different monitor cord, or changing monitors. You need to figure out if it's the PC or the Monitor that has gone bad.
HP PAVILION... | Answered on Jul 02, 2010
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
83 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
connect dvd rw laptop
  • Computers & Internet
