Help!!! my toshiba 1400- s151 sattelite laptop wont start up and is stuck on the black configure screen which says sorry for the inconvenience. what do i do
Try reinstalling windows. Before installation it will show you an error type that error in google and then you should have your answer to your problem. before that i suggest you check your ram cause this problem appears usually when ram is damaged.If damaged remove it and buy another one
Check the Wire Harness make sure it is back in the correct place and plugged in all the way into its designated plug. :) also, if that doesnt work then you can replace the LCD. Which is expensive.
It appears that the computer you bought on EBay only has the Windows opertating system installed. Did the seller give you a full specification and configuration including installed software?
What other parts are missing?
As for an Internet connection, you need a network card and an Internet Service Provider, have you arranged for this?
format your hard drive completly with this http://www.killdisk.com/downloadfree.htm
you have to create a boot cd with this software.
once formated reinstall your OS.
But if bios does not see this HD it it's also mean that is dead.
Seems like ur machine is having a problem booting the OS due to a problem with the windows files try reinstalling ur OS but be forewarned u will loose any and all files!
