20 Most Recent
Toshiba Satellite A205-S4617 Notebook Questions & Answers
Toshiba Netbook NB200 sound and microphone working but not on MSN
up vote 0
down vote If you have Windows XP:
- Open the Control Panel
- Select Sounds and Audio Devices ? Audio Tab
- Go to Volume on Sound Recording
- Select Advance under Microphone and check the Do not monitor check-box.
This way, you should be able to keep using the microphone without feedback from any speakers.
Go to the Control Panel, and click on Sounds and Audio Devices.
Under Device volume, click on Advanced.
Under Microphone, check the Mute button. If the "Microphone" section is missing, go to Options -> Properties, and under the Playback section, enable it.
10/3/2017 2:38:15 PM •
Toshiba...
Answered
on Oct 03, 2017
I need spanish
The @ is at Alt-Gr + Q
now to change it to spanish you will have to reinstall a spanish operating system. If its a new laptop, with a legal operating system, then i would try to trade it with the manufacturer.
3/29/2016 4:52:27 PM •
Toshiba...
Answered
on Mar 29, 2016
Disturbing sound
Check for dust in the fan, The fan in my old Toshiba was noisy too at the start but once up to speed it was quiet. I bought a replacement fan and fitted it. Easy to do as the noise was starting to irritate me.
8/8/2014 2:03:35 PM •
Toshiba...
Answered
on Aug 08, 2014
Itoshiba satellite bootmgr compressed how to fix t
When first turning it on press ESC or F10. This should take you to the BIOS screen. In this screen you can choose to reset the OS to factory settings. It is possible you have a rootkit virus or similar malicious bug. If so, a certified tech may need to address
the issue.
4/11/2014 9:55:40 AM •
Toshiba...
Answered
on Apr 11, 2014
Computer will not power up
You can detach the main battery, and leave it for a week. If next week your laptop still has the same problem, then it means your laptop is dead.
2/18/2014 2:24:01 AM •
Toshiba...
Answered
on Feb 18, 2014
Touch pad not working
Hi Cheryll,
Make sure there are no problems with the driver installed on your machine by going to Control Panel->Device Manager and see if there are any question\exclamation marks on one of the drivers. While you are at the device manager you can check the touch pad driver version and update it to the latest from the manufacturer website if needed. To check the driver version double click the touch pad and go to the Driver tab. You will see it under driver version.
Also some netbooks got an hardware button to shutdown the Touch Pad.
Regards,
TheSmacker.
1/21/2014 12:36:21 PM •
Toshiba...
Answered
on Jan 21, 2014
My Satellite A100 laptop has no numerric key pad so how can I type special characters?
you should have numbers on the keyboard which you can access using the Fn button... you can also use these without the FN button by htting the NumLock button, then use as normal keypad....
other that that try using the Alt button and the Fn with the corresponding digits.So hold down Alt, FN and tap the corresponding digits/letters on the keyboard.
If you need to use a numpad a lot, then can purchase a USB numpad - often included with USB kits from gadget shops.
11/30/2013 11:05:19 PM •
Toshiba...
Answered
on Nov 30, 2013
Web cam operation
check if both webcam driver and software was installed first,if not download and install them.if they were,then click the start button and look out for toshiba,it should be there when u click on the toshiba folder..
11/22/2013 1:54:24 PM •
Toshiba...
Answered
on Nov 22, 2013
