20 Most Recent
Toshiba Satellite 1405-S151 Notebook Questions & Answers
When turned on, i only
Modern TVs are basically a computer. In case you are talking about your computer, this is very old as it is copyright 1997. So, is this failure of a hard-drive of a computer, or failure of the high voltage circuit on a TV?
12/5/2017 3:10:36 PM •
Toshiba...
Answered
on Dec 05, 2017
When turned on a black
Sounds like a BIOS password was set. You can open it up and disconnect the BIOS battery. That works on most models. Google the specs of your model and try it. If that is your problem you can't use a recovery cd. You can also just reload the OS with the original cd and you will know if it is a BIOS password because it will not reload the OS from the cd because your BIOS password will appear first. Rady
3/31/2011 5:18:21 AM •
Toshiba...
Answered
on Mar 31, 2011
My question (and neither LEXAR nor Panasonic nor
Yes - the SDHC memory card is a different format than the regular SD card. If you're trying to read the card on the laptop, chances are the reader slot is not capable of doing so even though it fits. You'll need an adapter that reads the SDHC to USB and connect it to the laptop.
1/19/2011 7:29:13 PM •
Toshiba...
Answered
on Jan 19, 2011
I have a toshiba satelltte
try removing the battery from the laptop and plug it back after 3 minutes... It should wipe the bios password...
1/15/2011 6:29:45 PM •
Toshiba...
Answered
on Jan 15, 2011
My Toshiba Satellite 1405-S151 is
if your TOSHIBA laptop is doing this then check the RAM(memory)
if the problem persist check the Processor,
Likewise If it continues use WorkStation on the VGA Chip;
thats all
12/21/2010 8:48:42 PM •
Toshiba...
Answered
on Dec 21, 2010
My laptop is making a
This is a typical error message you get when the CMOS battery cannot hold on any charge. This battery powers the CMOS memory which stores the BIOS settings, date & time while the laptop is switched off.
In order to resolve this problem, you need to replace this battery. Normally, this will require that you disassemble your laptop partially or fully in order to get access to this battery & replace it.
11/21/2010 8:07:26 PM •
Toshiba...
Answered
on Nov 21, 2010
Am not able to get
sanathanchan,
Here is the website for driver support for your model of Toshiba Satellite:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=191872&rpn=PS140U&modelFilter=1405-S151&selCategory=2756709&selFamily=1073768663
Hope this helps.
-S
10/19/2010 11:49:23 AM •
Toshiba...
Answered
on Oct 19, 2010
