20 Most Recent
Zyxel P660HW-D1 Router Questions & Answers
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
NAT 3 in PS3 Router Zyxel P-660HW-T1 v2
Yeah I had this problem but she's fixed. No need to upgrade the firmware me thinks.
1) Type in "192.168.1.1" into the address bar of your browser. The log in page for your browser appears.
2) Enter your password - by default this is "1234", but you might have changed it. If you have changed it before log in with that new one.
A page should load with a lots of boring information. On the left side there should be a panel of stuff, what you want is "advanced settings". If advanced settings IS there on the left go to step "a" below. If advanced settings (or in fact anything) IS NOT down the left proceed to step "b" below.
a) Happy days. All you have to do is click the "+" beside advanced settings to expand it, then select UPnP. Then just click ALL of the boxes (there's 3 of them I think). That's it.
b) You are logged into some sort of stupid mode where you can't change anything. All you can do is refresh the page or log out. This is probably because you entered "1234" as the password, but in fact this password has previously been changed by you or someone else. So go back to the log in screen (192.168.1.1 in the address bar) and put in the one you changed it to, if you can remember it. If you do remember it and log in successfully (successfully being that you can see "advanced settings" on the left), go back to step "a" above. If you still can't get to that page it means you don't know your password. So you're going to have to reset your router. Go to step "c".
c) Resetting your router. Turn the router off. Then hold the reset button for 30 seconds and power on the router at the same time. Now I think you'll have to set up your router again like when you got if first, to connect to the internet, so do it. Then log in to 192.168.1.1 again. This time the password "1234" should bring you to the proper screen with advanced settings. If it does go to step "a". If it doesn't go to step "d".
d) You'll have to default reset your router. Turn it off. Turn it on and hold reset for 15 seconds. Some light will flash. Release button and let it reboot. Now log in to 192.168.1.1 again. If it works and you can select "advanced settings" go to step"a". If you STILL can't see advanced settings you're at the end of the line and I don't know what to do. Contact your provider or something.
If you haven't done this already...on your ps3:
Open up network >> internet connection. Choose wireless/wired - whichever you want. Choose "Address settings" - "custom", "IP address" - choose manual.Enter these:
IP address - "192.168.1.50"
Subnet Mask - "255.255.255.0"
Default Router - "192.168.1.1"
Primary DNS and Secondary DNS same as default router.
Then enter than. Don't know what MTU is (it'll come up next). You're done.
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
How do i change my NAT to strict to open
the zyxel is used for secure network.
you need to enter the admin passw first and enter on port forwarding the ports numbers of XBOX
enter folling ports
TCP 80
UDP 88
UDP 3074
TCP 3074
UDP 53
TCP 53
Now test again.
I have forgotten my password for my zyxel router.
If you forgot the password of your router. If ever you already change it from default, resetting is the only way now I know. If default consult your manual.
There's always a reset pin on every router. Go to manufacturer's site and download the manual for your particular model. Scan thru pages and look for Resetting the router.
Find wep key
Wep key in on the side, back or bottom of your router. usually about 15 or so numbers and letters. Mac key ore pc key etc.
Key phrase
First, go to this site -
660HW Series ZyXEL - and download a manual for the ZyXEL P660HW-D1.
Quick start guide
Download Library
Next, hook up the router to your computer with a LAN cable. Open a browser and enter 192.168.1.1 into the url address window. The default login is 1234
. Then configure the wireless settings - see pages 6 & 7 of the guide.
Wireless key phrase
Try typing the router ip address into your search engine and you should get a page where you can make adjustments to the basic setup
I dont no mypassword of wifi
If you got WPS capability on the device you are trying to connect you can push the WPS-button on the router, or you can login to the administration interface on the router (IP-address might be underneath unless you don't know it) and change the password to your liking. If you don't know the login and password for your interface then i guess the last resort is to find the reset button on the router and use the provided login that usually is found on a sticker underneath the device (your router), and simply set a new password for your WIFI.
