20 Most Recent
Compaq Presario M2000 Notebook Questions & Answers
Vertical lines in my laptop screen
BEWARE SPAM NUMBER +1-800-532-4187 BELOW
A VGA monitor is a monitor that uses a standard VGA connector to attach to your PC/laptop. A VGA connector is a small D shaped socket connector, about ½ inch long and ¼ inch wide. Its usually blue with three rows of holes (total of 15 holes) where pins from the mating connector match up with. The only other thing that may look like it is a serial port but that is easy to distinguish, it has two rows of pins for a total of 9.
What 24 sever is suggesting you do is connect another monitor to see if the problem shows up there as well. I?ll be surprised if it does since usually this type of display problem on a laptop more often than not is due to a defective connection inside the laptop screen area.
A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change. If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you?re lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on or take it to your local repair shop.
I have a Hp DV2550
lines in BIOS means what, it means the screen is bad.
end story. (or can be weak power pack, 19vdc 65watts(min) is it?)
BIOS runs with no HDD !! runs with no CDRom,
so that means it cant be OS related at all. ever. in this case.
HP Pavilion dv2550se Notebook PC (my guess at true name)HP does not support W7 on this plateform.that means , you are only own STEAM, with drivers. but if all you need is one driver to work, you can get that , that the maker of that GPU chip.This PC CAME WITH VISTA ONLY. EVER.THE PC DAY1 had 1 chips offered, one intel, other nvidia. we PCI scan all hardware to find whats there,so can you , or ask hp for that fact by telling them your serial number, we are not HP here its just a silly chat room here.
Can install software on ma lap top
Please ensure that you have admin rights to install software on your laptop. Otherwise try creating a new windows profile and then install software.
My notebook is overheating
you need to buy a
notebook cooling pad, if you don't have one on your laptop. this can help to reduce overheating of the laptop..
click
HERE to see.
How to select correct anti virus program for laptop?
Go here and determine which one meets your needs: http://www.pcantivirusreviews.com/Comparison/Top-Antivirus.html?avrtsid=2&kw={Top+10+Virus+Protection}&gclid=Cj0KEQjw6tepBRDLqLnxouaY_pkBEiQAPIOiBuAtEiB5uv1nvrY9VM2J-4rbuOG5TP17rm1FqTAfq5EaAmIa8P8HAQ
Many of these products offer free versions, or search for 'free antivirus software', select one and install.
Google chrome crashed on my laptop, how can i relaunch or fix it?
Ctrl+Alt+Del and open task manager. In processes, sort on names and remove all references to Chrome by stopping processes. Go to applications and remove any reference to Chrome. If you have a cleaning program such as ccleaner, run cleaner on registry and computer.
Try to restart to see if the error has been resolved.
Good luck.
Sound driver m2000
To help you to get the driver, the information needed is not the model of your computer but your sound card. Check woth some system diagnostics app like Sysoft Sndra - get it searching google
Red horizonal line on kindle screen
Your screen has a problem. No way to solve this problem by any software. If it is on warranty, claim service If warranty is over, I'm not sure it can be repaired, probably screen must be changed and it is quite expensive.
Sound prob in pc
If the sound shows in windows & sound r'nt hear then speaker problem & if sound is ok then IC problem. & Your Question is not so clear? Please
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
Hello! I've been using my
its the lifetime getting over of the lcd display , either get it replaced or just ignore it . Nothing of repairment can be applied to it . I am an authorised repairer for Compaq at my region . Sorry that we coudnt help you sir ,
Thankyou , please vote for me .
Fix vertical lines on lenovo 3000 n100 laptop
depends, are the lines in the OS, from the time windows first opens?when you use CDRom or DVD player or when you use any player active in your system. I need more precise information to help you
