SOURCE: No ink
hi i am a certified Canon repair tech for this fax. the problem that you are having is very common and has to do with two things. the cartridge and the purge/cleaning unit. what you can try is this open the printer and center the carridge unit and remove the cartridge. unplug the machine while it is still centered. on the right hand side you will see the purge unit. in the center of the purge unit is what looks like a retanglar pad. mix a water soap solution and apply to pad just soaking it. let it sit for a few minutes. take the ink cartridge and wipe the bottom of the cartridge with a damp soapy cloth. also if you look at the cartridge there is a little breating hole you can hold a cloth on the bottom and gently blow in that hole it will purge ink through the bottom of the cartridge. install the cartridge in the machine close the front door and replug in the power cord. you might still have to run a few cleaning cycles. hope this helps.
SOURCE: Machine not feeding paper through
try cleaning the rubber rollers with a damp cloth and make sure there clean. also check to see if the paper is making contact with paper.
if that fails check the leading edge of the paper for damage incase something maybe blocking paper.
SOURCE: My Canon Laser Class 7000 has a problem on the
Easy one. This unit has several parts in the automatic document feeder (aka ADF) that simply wear out. As far as I know the parts are still availble from a reputable canon repair center. The lower feed assy is the most likely contributer to your issues. This is sold as an entire assy. Not exactly for the faint of screwdriver. Should be done by a skilled tech.
Good luck
SOURCE: Continually getting incorrect paper size on print
Make sure that the page size of the doc is set to A4,What happens when u make a copy?
