20 Most Recent Canon FAX-L800 Plain Paper Laser Questions & Answers
Hi! this is Alex Walker expert to help you to fix this issue for you call me on +1(518)348-9393 Thank You
Canon FAX-L800... | Answered on Aug 10, 2017
Have you tested the telephone line to see if it has dial tone. Unplug the fax from the line and plug in a analogue phone to test this.While you are there check the extension number with the phone to make sure you are still on the same number. You can do this by dialing any phone with a display ie a mobile.
Canon FAX-L800... | Answered on May 03, 2011
Unless I'm misunderstanding your question, your fax machine has nothing to do with the incoming fax number. That's assigned by your phone service provider to the telephone line the fax machine is connected to. The only way to change that number would be connect the machine to a different phone line. This might be as simple as just plugging the phone cord into another jack if that line already appears at a convenient location, or it might mean a visit from a technician to place a jack where it's needed. Or you can contact your phone service provider about assigning a new number.
I hope this has helped. If not, please post a comment with more information about your question and I'll try to help further.
Canon FAX-L800... | Answered on Oct 11, 2010
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Canon FAX-L800... | Answered on Nov 19, 2009
clean the feed rollers inthe document feeder with water or alcohol
Canon FAX-L800... | Answered on Oct 06, 2009
Hi
You can set the unit to transfer the documents on to another fax. This is quite a longwinded process so I have included a link to the manual for this model as you will need to study this before you can achieve the transfer and my post would be running into several pages otherwise.
The link is here and the section you need to look at begins at page 141 on chapter 7-11
http://ww2.canon.hu/download/kezikonyv//fax-l800_Users-Guide_ENG.pdf
I realise you need to get these faxes out urgently so I am rushing my answer a bit!
In regards to the problem with the replace cartridge - I would recommend that when you get your faxes through you disconnect the machine from its power supply for 30 minutes then power up again to see if the issue resolves.
If not it is possible that the cartridge itself is faulty.
I hope this helps. Please do rate my answer. Many Thanks.
Canon FAX-L800... | Answered on Sep 06, 2009
I'm not sure what you mean but if you are referring to a dual line then no. You cannot have two lines coming into the L800.
Canon FAX-L800... | Answered on Jul 06, 2009
eigher program it to accept afax in the functions menu or push start when it rings
Canon FAX-L800... | Answered on Jun 06, 2009
Can you send? Can you make copies? Do you have it set to auto receive?Is the phone cord plugged into the line socket? Let me know!
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Canon FAX-L800... | Answered on Apr 21, 2009
Open the covers off the one touch speed dials.Press the Dataregestration button,dataregistration will be displayed on the screen.press set,user settings will be displayed.press set again,date and time settings will be displayed.press set again.change the date and time and press set.
Canon FAX-L800... | Answered on Feb 27, 2009
You can download the user manual for this, just go to this link http://download.canon.it/manuali_operatore/files/L800ugen.pdf
Canon FAX-L800... | Answered on Dec 02, 2008
Unplug the power cord for 10 seconds.
Canon FAX-L800... | Answered on Oct 28, 2008
Can you send?
Are there any error messages?
Is the other party dialing the correct number?
Is the phone line plugged into the LINE port?
GO TO TX REPORT SETTINGS AND SET OUTPUT 'YES'
Canon FAX-L800... | Answered on Oct 24, 2008
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Canon FAX-L800... | Answered on Oct 23, 2008
Canon FAX-L800 Plain Paper Laser Logo
Popular Tags
40 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon fax l800 want use
  • Office Equipment & Supplies
