20 Most Recent Konica Minolta PagePro 1350W Laser Printer Questions & Answers
if you keep it clean yourself that print much keeps it clean use your op manual to check for required maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Feb 25, 2018
Pull all imaging units out and clean the laser with the wand provided either in tray or on front door.
Konica Minolta... | Answered on Sep 23, 2017
I take a picture using a screen capture program/app then print the picture. It also make it possible to overlay things such as the (faded) word (COPY) on top or underneath it, if you want. When I use the COPY method, I print the faded word COPY first then re-run the paper through to print the rest
Konica Minolta... | Answered on Jun 05, 2017
user isopropol alchol or small amount of water and dish detergent
Konica Minolta... | Answered on Jul 03, 2016
Check the heater element in the fuser assembly, if damaged replace.
Konica Minolta... | Answered on May 30, 2016
This is the link I found: http://crm01.konicaminoltaeurope.com/41256849005CE173/LogDwl?OpenAgent&CB3863A45667F72FC125701F002C0AE0/$File/english_2k_xp.exe You can also try the following: http://www.printer-konicaminolta.com/apac/support Please update the question & let us know if the information given was useful to you - Good Luck!
Konica Minolta... | Answered on May 06, 2016
You will have to go into printer settings and purge all document printing.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Konica Minolta... | Answered on Mar 03, 2016
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Konica Minolta... | Answered on Jan 18, 2016
clean the rollers and replace the sep pad or sep roller which is the bottom roller, first one is pickup top one transfer bottom sep. or replace all
Konica Minolta... | Answered on Dec 29, 2015
You need to provide more info
Konica Minolta... | Answered on Dec 28, 2015
Yes Sir/Mam what is the problem?
In some KonicaMinolta loose counter wire make start button blinking, fix wiring.
Konica Minolta... | Answered on Nov 19, 2015
replace the toner with a konicaminolta orginal
try this
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Konica Minolta... | Answered on Jul 19, 2015
what error sir/mam?
Konica Minolta... | Answered on May 21, 2015
Any info such control panel. display or what the machine was doing before this happen
Clean the contact of the small electrical contact on the cartridge and where those contacts make contact on the machine normally front of the machine with alcohol. some times hands get oil on the contact so there no good electrical contact, though occasionally you do get a bad cartridge.
Konica Minolta PagePro 1350W Laser Printer Logo
302 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
PagePro Konica Minolta
  • PagePro Konica Minolta
Most Popular Question
printer got stuck in document will not
  • Office Equipment & Supplies
