Sharp LC-32SB24U 32 in. LCD TV Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keep always blinking the green lights indicator ones i plug the power cord. no video, no raster on the screen.
Loretta Northcutt
Level 3:
  • Sharp Master 736 Answers
  • Posted on Dec 09, 2010
Loretta Northcutt
Sharp Master
Level 3:
Answers
736
Questions
0
Helped
254389
Points
2334
The green lights on a Sharp television indicate a problem. The number of blinks is a code. The television has gone into a coma in order to protect itself. You can force this television on by doing this. Unplug the television. Hold down the vol+ and channel down button on the television and while holding them down still plug the television in. This is a temporary way to view the television but the problem will get worse if not repaired. Should the television power on this way unplug it when you want to turn it off without pressing the power button at all.
  • irishtech Jul 25, 2011
    Thanks. The forced power reset worked but now I have a solid green light with black/blank screen. Ch 4 indicator appears in upper right briefly then disappears and no audio. Will read further on this.
Sony TV set, KV20FS120 BA6 chassis: light blinks, set isn't coming on. Why?
Sony sets like this have a built-in self-diagnostic function.
The blinks of the Standby LED are the self-diagnostic codes.
There may be more than one error. The blinks indicate only the first error.
Unlug the set. Wait 30 seconds.
Prepare to count the number of times the Standby LED blinks.
Plug the set back in. Count the blinks.
2 blinks
  • Diagnostic Item Description: +B overcurrent (OCP)
  • Probable cause:
    • H.OUT (Q506) is shorted. (A Board) (20"/21" models only)
    • RGB Amp (IC1751) is shorted. (CV Board)
  • Detected Symptoms:
    • Power does not come on.
    • Load on power line is shorted.
4 blinks
  • Diagnostic Item Description: I-Prot
  • Probable cause:
    • +13V is not supplied. (A Board)
    • IC545 is faulty. (A Board)
    • Has entered standby state after horizontal raster.
    • Vertical deflection pulse is stopped.
    • Power line is shorted or power supply is stopped
5 Blinks
  • Diagnostic Item Description: IK (AKB)
  • Probable cause:
    • Video OUT (IC545) is faulty. (A Board)
    • IC001 is faulty. (A Board)
    • Screen (G2) is improperly adjusted.
    • No raster is generated.
    • CRT Cathode current detection reference pulse output is small.
The above may be of little help. Your best bet is to download the service manual for the KV20FS120.
...Google search: Sony KV20FS120 service manual
Xbox 360 still Blinking Green without any Display on Screen
Replace the cords connecting to your TV. This usually happens when one or all of the cords get old and need to be replaced.
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Black Screen no sound, Green light blinks for some time then goes red then recycles back to green
Tv have power LED lights indication are blinking and recycle blinking.Mean the tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
2helpful
2answers
IBM X226 server
i have two x-series server but in one server with one power cords it is showing green light but in case of another server it is comming yellow light.
Offline and blinking lights
A couple suggestions. Unplug the usb cable from the pc to the printer, make sure there is no paper jammed in the machine, unplug the machine from the wall and see if you can move the print head left to right freely. If nothing is obstructing it plig the power cord in with out the usb cord plugged in. See if the machine goes to ready. If all of these fail, that means the main board has been damaged by a power surge, and it would be cheaper to replace the machine than repair it. Good luck!
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
