20 Most Recent Dell E172FP 17" LCD Flat Panel Monitor Questions & Answers
Screen suddenly went blank except for a self test box
well in order to get rid of the self test window from your monitor... check the cable that connects your monitor to system tower & reset the connection... becase that is the only possible cause of the self test showing up on your monitor...
" as the self test option only appears when there is no video signal going from your video card to the monitor...
2/5/2024 9:28:45 AM • Dell E172FP 17"... • Answered on Feb 05, 2024
Contrast/Brightness Menu repeatedly pops on screen/won't go away
What kind of system do you have there? Regular PC + monitor or All-in-one/Laptop?
12/30/2017 12:22:49 PM • Dell E172FP 17"... • Answered on Dec 30, 2017
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
5/21/2016 3:18:18 AM • Dell E172FP 17"... • Answered on May 21, 2016
3answers
Monitor won't stay illuminated for more than 2
Check for bad capacitors in the power supply section, also check for shorted out transistors (4) C5706/5707 in the inverter circuits.
1/7/2016 12:45:01 AM • Dell E172FP 17"... • Answered on Jan 07, 2016
Flashing power light on Dell
I had the same problem and it only cost me $6 in parts and shipping from Mouser and you'll need a soldering iron. I made a video on how I fixed this problem on my Dell E178FPb. Mouser Electronics Electronic Components Distributor
6/8/2015 6:52:57 PM • Dell E172FP 17"... • Answered on Jun 08, 2015
How to get rid of main menu icon popping up
Anonymous, Turn off. Disconnect the power cord from the rear/bottom. Press and hold in the power button for 10 seconds. Reconnect the power cord. Power on. If that does not stop it, it is broken and will need to be replaced. Thank You, Dell -Jesse L Dell Social Media and Communities
2/19/2015 3:01:38 PM • Dell E172FP 17"... • Answered on Feb 19, 2015
Dell flat screen monitor is repeating images
"Shadowing" effect fixed by separating the wires in back. Touching wires cause crosstalk of signals . Immediate fix.
8/12/2014 5:19:03 PM • Dell E172FP 17"... • Answered on Aug 12, 2014
What is vga/dvi cables
VGA and DVI is in the way the video signals travel. VGA connectors and cables carry analog signals while DVI can carry both analog and digital. DVI is newer and offers better, sharper display compared to VGA. You can easily tell them apart because VGA connectors (and ports) are blue while DVI connectors are white. Click the link below to see an image of them. http://www.hardwaresecrets.com/imageview.php?image=8131
8/5/2014 3:49:38 AM • Dell E172FP 17"... • Answered on Aug 05, 2014
Padlock icon
Many monitors have an on-screen display lock (the padlock icon) that seems to get stuck. Various suggestions in the links below - the one that seems to work most often is to hold the monitor's menu button down for 15-20 seconds to get the screen menu, then either try unlocking the OSD (On Screen Display) or do a factory reset on the monitor. http://www.fixya.com/support/t448684-flashing_padlock_icon_in_middle_screen http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm Different monitors have slightly different menus, but if it's a Dell monitor you can find the manual below (under Display): http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~cat=3
7/30/2014 6:55:15 AM • Dell E172FP 17"... • Answered on Jul 30, 2014
Lost power cord for sound board
Browse ebay website.
3/1/2014 5:59:09 AM • Dell E172FP 17"... • Answered on Mar 01, 2014
We lost our power cord for the sound board. How can we get a replacement?
Take screen to computer shop and ask for cable
1/4/2014 6:21:39 PM • Dell E172FP 17"... • Answered on Jan 04, 2014
How do I make my PC get the video signal?
connect the vga/hdmi monitor cable to your pc and let the windows search wizards to detect your new hardware. follow the instruction or install the cd driver for your monitorJoel
4/22/2013 2:32:24 AM • Dell E172FP 17"... • Answered on Apr 22, 2013
My monitor keeps shutting off
9 times out of 10 this is a capacitor burned out on the power board. To repair it you will have to have some soldering ability and be able to get the parts or you can see if you can get a power board for your monitor. http://compare.ebay.com/like/310644115747?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar 27.99
4/4/2013 6:05:21 PM • Dell E172FP 17"... • Answered on Apr 04, 2013
Dell model no E198FPf LCD Monitor has agreen light but wont turn on
Your problem is caused by a failure of the filter capacitors in the power supply board, this is a common issue on LCD monitors. Here is a link to repair information for this model. You can repair the monitor by replacing the filter capacitors. http://www.ccl-la.com/catalog/product_info.php?products_id=195
2/9/2013 5:31:26 AM • Dell E172FP 17"... • Answered on Feb 09, 2013
Where do i set the brightness of the monitor
dear sale out this monitor and buy new monitor
12/4/2012 6:18:21 PM • Dell E172FP 17"... • Answered on Dec 04, 2012
Where is the volume control for my dell
Here is a link to Dell for your monitor: http://support.dell.com/support/edocs/monitors/e172fp/En/
11/10/2012 3:42:16 PM • Dell E172FP 17"... • Answered on Nov 10, 2012
Monitor green light is on but no image what's the problem?
Pretty good bet that your monitor power supply has bad caps. There are about 6-10 caps that age and "bulge". The fix is simple. Google it. Total cost to fix (if you know how to solder) is probably less than $2.00.
6/9/2012 12:41:21 AM • Dell E172FP 17"... • Answered on Jun 09, 2012
Dell E172FP 17" LCD Flat Panel Monitor Logo
244 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
need electronic circuit dell e172fp 17
  • Computers & Internet
