20 Most Recent Dell 942 All-In-One InkJet Printer Questions & Answers
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
11/4/2019 9:30:22 AM • Dell 942... • Answered on Nov 04, 2019
Error 1203 on Dell 942
We had our computer to crash and now have windows vista instead of windows xp. Our printer says error code 1203. We have cleaned the printer heads and we still cannot get our printer to work. Is the printer not compatable with windows vista? How can we fix this problem dee
5/1/2019 6:35:15 AM • Dell 942... • Answered on May 01, 2019
Dell all in one 942
Printer
11/12/2017 1:55:40 PM • Dell 942... • Answered on Nov 12, 2017
0answers
Dell AIO 942 error 1203
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&docid=554361&doclang=en&l=en&s=gen&cs=GO TO ABOVE SITE FOLLOW THE INSTRUCTIONS STRICTLY...Good day with ur printer...THANK U..
11/23/2012 6:37:22 PM • Dell 942... • Answered on Nov 23, 2012
0answers
I took my computer to Staples to have it cleaned, etc. Now my printer does not work. I've tried unplugging and plugging it in again, but no luck.
That means the drivers for the printer are corrupt or have been deleted. To solve this, firstly use the printer software cd if you have one to install the printer drivers again. If you do not have the cd then you can go on google and type the name of the printer followed by the word 'download' for example xerox phase 3100 printer drivers download
12/10/2011 11:05:16 PM • Dell 942... • Answered on Dec 10, 2011
The file currently in the
Try looking on the bottom right side of your pc, near the clock to find the picture of the printer or Icon for the print Que. Sometimes you have to click on a little arrow in this area to open it up and view all available. Find the picture of the printer and right click with your mouse on top of it. choose all printers and this should bring up a list of documents which have failed to print. Find the document and click on it then choose "delete" until there are none left on the list. make sure you use the "all printers" choice and not just the one listed in the name of your printer to clear this que. if this does not work, let me know by using the comment or reply links next to your question on Fixya and I will send more troubleshooting instructions.
9/15/2011 11:22:59 PM • Dell 942... • Answered on Sep 15, 2011
0answers
0answers
The printer doesn't feed the paper in evenly,
>>Sounds as if the rollers have either dried out, or gummed up in spots causing unequal draw down.
Try one page at a time to see if it will pull down and print.
>>Something is blocking the rollers that feed the paper into the printer. Inspect the printer and free it from any blockage such as torn up paper resulting from a paper jam.
6/8/2011 2:55:00 PM • Dell 942... • Answered on Jun 08, 2011
Where do i find my
Hi idavi1515, to "Update the Driver / Software."
Go to this "Website Link," below, for Dell 942 All-In-One.
Fill-in all information required.
Ie: Brand Name, Model #, and Operating System...
"OS" are: XP, Vista, and Windows 7
Select the [Drivers] you need from the "List."
"Download the Drivers."
!"Take a moment to rate the help."
Thanks paul7of9
Cick here: http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=+Dell+942+All-In-One&cat=sup&x=6&y=8
3/21/2011 5:57:59 PM • Dell 942... • Answered on Mar 21, 2011
Trying to attach Dell 942
Try Installing the drivers & software you got with the printer. USE Mac drivers not windows
3/15/2011 8:47:32 AM • Dell 942... • Answered on Mar 15, 2011
2answers
Lines show up throughout print jobs
Your print heads most likely need to be cleaned.
When you don't use your ink carts for a while, when you get new ink carts that have been stored in warehouses for a number of months, or when you have refilled a slightly too dry ink cart, the print head nozzles on the bottom of the ink carts get clogged with dried ink. The printer head cleaner menu will not disolve the dried ink. Water will. Try this. Soak the bottom of the clogged ink cart in 1/2 inch of hot water for 15-30 minutes. Blot dry with clean paper towel(you should see the ink color on the towel). Retry.
3/7/2011 5:00:23 PM • Dell 942... • Answered on Mar 07, 2011
How can I download the
try on this page
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=W764&osl=en&SystemID=PRN_ALL_A942&catid=-1&impid=-1
2/21/2011 6:43:42 PM • Dell 942... • Answered on Feb 21, 2011
Carriage slams back and forth
I cleaned the encoder strip with alcohol and a soft T-shirt. IT fixed it for me.
12/7/2010 11:41:05 PM • Dell 942... • Answered on Dec 07, 2010
Dell 942 printer cycles on and off repeatally
Are the new cartridges from Dell?
I would try cleaning the contacts on the printer. Use a Q-tip and some isopropyl alchohol and clean the copper contacts where you cartridge plugs in. While your at it you might as well clean the copper contacts on the cartridge also. It is very common that Dell cartridges have this error. If that doesn't work send them back to Dell. I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
11/12/2010 12:09:03 AM • Dell 942... • Answered on Nov 12, 2010
PARTS LOOSE INSIDE HOW DO TAKE IT APART WITH OUT
You don't. Dell printers are made to be disposable. Nicer machines can be worked on limitedly but really all consumer grade ink printers are disposable. Sad I know. I would reccomend staying away from Dell, Lexmark, IBM and Kodak as they are all made by Lexmark. Generally not the highest quality machines with expensive ink. New Canon machines that take the CLI-221 cartridges are very nice along with most new HPs.
10/29/2010 11:17:36 PM • Dell 942... • Answered on Oct 29, 2010
Dell 942 All-In-One InkJet Printer Logo
186 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
printer doesn 39 t feed paper in
  • Office Equipment & Supplies
