20 Most Recent Invacare Pronto M51 Power Wheelchair Questions & Answers
How many times does the service light blink.
Invacare Pronto... | Answered on May 13, 2019
SADLY WE DO NOT HAVE A MANUAL TO LOOK THAT UP IN SUGGEST YOU TRY LOOKING FOR THEIR WEBSITE AND IF THEY HAVE TECHNICAL SUPPORT
Invacare Pronto... | Answered on Feb 09, 2019
check to make sure that there are no missing or bent pins on the lead and socket that connects the power module and the controller (joystick) often the small round plug and socket get bent pins and stop working, if bent try to straighten if missing then you will need a replacement lead or controller (joystick) ebay is a great place to pick up cheap wheelchair parts, do a search on google first as there are several types of controller and leads that can be fitted to this chair, look for a picture that matches the type you have and then search ebay for it, the controllers start from about £25 - 40 the leads from about £15 - £30 still much cheaper that getting a mobility shop to fix it.
Invacare Pronto... | Answered on Jan 17, 2019
Solenoid Brake Trip
The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the system connections are secure.
check that the free wheel lever is disengaged, alway switch off the controller (joystick) before making adjustment or unplugging connectors as the error code will not clear until the joystick is switched off and on again. check connector blocks and wires for damage or being dirty contacts. clean use soft wire brush to clean the connector contacts.
hi, i suggest you use a socket slightly smaller than the grease seal diameter , is the circlip that holds the bearing in place flat ? gently tap the seal into place making sure it goes in even all round.
regards
Rob
Invacare Pronto... | Answered on Dec 19, 2018
If you are referring to the three lights as the three colors red, yellow and green. Then you would normally get that. The circuit is telling you that something is attached to the chair, has faulty component or a motor unlocked. and you can't move.The rapid blinking would tell me that you have a controller fault or a motor fault and a rapid scroll left to right would be an inhibit. I would need to know which one it is doing to know for sure what what to look for. If it is just three lights then I would definitely look at the joystick and/or controller being faulty.
Invacare Pronto... | Answered on Dec 07, 2018
Yes it does.
The new switch is the problem. The old toggle had a momentary ON when turned on and a jumper wire on two of the three toggle contacts.
Invacare Pronto... | Answered on Feb 07, 2018
The M51 does not have a stability locking kit. The Invacare TDX SP has a gas strut stability locking kit that just had an extensive recall campaign associated with it. Please describe your issue in greater detail.
Invacare Pronto... | Answered on Dec 10, 2017
Turn on chair, move joystick forward till it beeps, then all the way back till it beeps, and then let go of joystick, it should fire up.
Invacare Pronto... | Answered on Oct 11, 2017
use locktite on the threads
Invacare Pronto... | Answered on Apr 16, 2017
Take the motor connection and interchange the right motor with the left one. if the problem moves to the right motor then it is the motor or its wiring. If it does not move when changing the the connections then it is a problem in the controller. hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Invacare Pronto... | Answered on Sep 04, 2016
Most likely you need new batteries. On the M51 powerchair the batteries are located in the center under the seat. Step 1 - remove the seat by pulling up on the swivel handle while lifting straight up, the seat weighs about 50 lbs. After removing the seat remove the center plastic cover by liting it off.
If you have an older model M51 the batteries will each have their own cover - to replace the batteries you will see several connectors that must be unplugged. The front and rear batteries each have different connectors so keep them separate. Lift out the batteries and follow the wiring for each replace the batteries. You will need 2 U1 batteries, available at sears or your local maedical equipment supply store ( Interstate has them too) Simply reverse the removal procedure to replace the batteries making sure you follow all the connections. - good luck
Tom
Invacare Pronto... | Answered on Aug 26, 2016
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
Invacare Pronto... | Answered on Jun 19, 2016
The drive wheel has a locking tab washer under the bolt which holds the wheel assembly on the end of the drive shaft. Step one is to bend the tab (or tabs) away from the side of the bolt. Put a socket on the bolt to remove it. Make note of the washer and lock tab orientation because there is another tab on the inside which locks into the motor shaft keyway. Spray lube into the shaft and keyway to free up the wheel and remove. A wheel puller is sometimes helpful here. When replacing the parts use Loctite on the bolt and tighten. The final step is to bend a lock tab up against the bolt head to keep it from backing out. The hard part of this whole process is removing the wheel assembly from the motor shaft. It may have seized on to the shaft. Place anti-seize or grease on the shaft after cleaning and before reassembly.
invacare com
Invacare Pronto... | Answered on Jun 10, 2016
David,
have someone check the freewheel handles are in drive position, then unplug charger.
Invacare Pronto... | Answered on May 15, 2016
Contact Invacare/Dealer for service.
Invacare Pronto... | Answered on Mar 27, 2016
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Invacare Pronto... | Answered on Mar 26, 2016
Invacare Pronto M51 Power Wheelchair Logo
298 questions posted
Top Invacare Health & Beauty Experts
Morne Olivier
Rob Hill
Rob Hill
Vincent_G
Vincent_G
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Invacare Health & Beauty
Most Popular Question
pronto m71 larger round grease seal
  • Health & Beauty
