20 Most Recent Sharp LC-32SB24U 32 in. LCD TV Questions & Answers
17answers
My 32" sharp lcd doesn't respond to the remote
Ok I just dealt with the Sharp customer support for this problem. 1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
... let me tell you I thought the lady was crazy when she was telling me this but it worked!
8/4/2021 6:37:44 AM • Sharp LC-32SB24U... • Answered on Aug 04, 2021
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . I wish that I had better news for you. Cindy Wells
6/4/2017 10:46:10 PM • Sharp LC-32SB24U... • Answered on Jun 04, 2017
LC-32SV24U
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. .
4/6/2017 1:00:41 AM • Sharp LC-32SB24U... • Answered on Apr 06, 2017
2answers
How to change pc mode of sharp into tv mode
Use the input selector to change back to TV. Usually the first input on the list.
9/12/2016 5:30:47 AM • Sharp LC-32SB24U... • Answered on Sep 12, 2016
I cant get my sharp gaa667wjsa to go to channel 3 or 4 so i can connect my convertor box
On the tuner type setup menu page select cable then set the TV to 3 or 4 and use the antenna connector on the TV.
9/12/2016 5:10:36 AM • Sharp LC-32SB24U... • Answered on Sep 12, 2016
Sharp LCD tv has sound and no picture, will a reset work?
Do this first. Shine a flashlite on the screen to see of you can see a picture with the TV on and listening to a program. If you CAN see a picture the backlight drivers are bad If no picture the T-con board is bad. You can get parts from here :www.shopjimmy.com
9/12/2016 4:53:34 AM • Sharp LC-32SB24U... • Answered on Sep 12, 2016
How do I update the firmware on my sharp lc-37rd2e I have a problem with hdmi on wii cosole I am currently on version 1.04
Get the update from Sharps website. Load it on an EMPTY formatted usb thumb drive. From he setup menu on the TV select software update.
9/12/2016 4:22:28 AM • Sharp LC-32SB24U... • Answered on Sep 12, 2016
How do I reset my tv?
I think you should contact to a mechanic rather resetting yourself because some parts of TV are dangerous to be touched....
7/8/2016 12:02:20 PM • Sharp LC-32SB24U... • Answered on Jul 08, 2016
Tv turns on and off
samsung wide lcd
2/27/2016 11:02:09 AM • Sharp LC-32SB24U... • Answered on Feb 27, 2016
2answers
Power light blinking no display on lc 32sb24u
Its almost always caused by bad capacitors on the power board. You can get a repair kit or the replacement power supply board from www.tvrepairworld.com
1/13/2016 9:09:19 PM • Sharp LC-32SB24U... • Answered on Jan 13, 2016
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left. Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.) If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.) I hope this helps. Cindy Wells
10/26/2015 11:58:51 PM • Sharp LC-32SB24U... • Answered on Oct 26, 2015
2answers
Sharp flat tv lc-32sb24u no audio was watching tv
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
10/1/2015 2:05:53 AM • Sharp LC-32SB24U... • Answered on Oct 01, 2015
Why does it keep cutting off?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
9/30/2015 6:39:28 AM • Sharp LC-32SB24U... • Answered on Sep 30, 2015
I need to program my apex remote to my sharp tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
9/14/2015 9:18:59 AM • Sharp LC-32SB24U... • Answered on Sep 14, 2015
Sharp LC-32SB24U 32 in. LCD TV Logo
312 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
roku get sharp model lc32sb24u
  • Televison & Video
