You need to evacuate the refrigerant urgent to get the moisture out of your system.When you insert refrigerant ,"let it pass through a drier before it get into your system refrigerator.Only then you have a moisture free refrigerator.Many refrigerant comes with moisture these days but no technicians use a drier to prevent the moisture to fill into the system.They love to see you come back so they can charge you money again.
SOURCE: Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
SOURCE: freezer control is set at
if its less than one year old you should be able to call for warranty service and have your machine fixed for free.
go to www.frigidaire.com and search for servicers in your zip code. If you have no luck with that let me know, i can further assist you.
SOURCE: freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
SOURCE: FRIGADIARE FSC23F7DSB7
hi
If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 2: Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3: Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4: Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
