20 Most Recent Frigidaire FRS26H5AS Side by Side Refrigerator Questions & Answers
The solenoid valves, located in the lower back of the refrigerator, where the water line enter the unit has a filter mesh at the inlet. Mineral formation or debris from the tube lines block the water pass and present the symptoms you describe. Also, when units do not have this filter mesh, the mineral deposit and debris obstruct the water valve mechanism and the water flow. If you have good pressure at the valve entrance, but not at the output, replace the solenoid valves.
Frigidaire... | Answered on Jan 18, 2018
You need to evacuate the refrigerant urgent to get the moisture out of your system.When you insert refrigerant ,"let it pass through a drier before it get into your system refrigerator.Only then you have a moisture free refrigerator.Many refrigerant comes with moisture these days but no technicians use a drier to prevent the moisture to fill into the system.They love to see you come back so they can charge you money again.
Frigidaire... | Answered on Nov 19, 2017
That oil is probably compressor oil. If the compressor leaks, you need a new fridge. Sometimes they only leak when they're charged up. That would explain the other symptoms.
Frigidaire... | Answered on Oct 16, 2017
Either damper assembly between fridge and freezer is not working correctly or the thermostat is bad
Frigidaire... | Answered on Sep 05, 2017
Possible defrost timer or thermostat failure.
Frigidaire... | Answered on Jul 11, 2017
When a fridge is first installed it is important it is adjusted to stand level and firm. If it was transported upright and hadn't been laid down it could then be switched on but if it had been laid down during transit or during installation it should be left to stand before switching on - some authorities say four hours and others say longer.
Failure to do either of these things can cause accelerated wear of the compressor and that could be the reason for the humming noise and vibration.
A friend has the same problem with his fridge and he freely admits it was never properly levelled. It began vibrating years ago for a short time when it starts but apart from that it continues to work quite well.
Just to be on the safe side of fairly sure, it would be a good idea to check the security of the compressor and fixings...
Frigidaire... | Answered on Apr 18, 2017
What is it doing, or not doing? Any alpha-numeric error codes or flashing lights?
Frigidaire... | Answered on Jan 04, 2015
Ice maker won't work if compressor will not run, of course. I would suspect the main circuit board if there was a bad surge of electricity, or the problem could be at the compressor, i.e., a bad relay, overload, or start capacitor.
Frigidaire... | Answered on Oct 03, 2014
The panel comes off some snap off others have a couple screws hidden under the drip tray. After removing the outer panel, you will see some screws holding the paddle in place.
Frigidaire... | Answered on Sep 28, 2014
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 03, 2014
Good Afternoon Friend,
I understand that you are receiving a 56 code on the display of your Frigidaire refrigerator, model# FRS26H5AS. I also see that it is not dispensing ice or water, even though you have reset it by unplugging it. The 56 is actually SB. This tells me that your refrigerator is in Sabbath mode. To exit the Sabbath mode, press and hold the down arrow and the plus sign, simultaneously for 5-10 seconds or until the display changes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 12, 2014
your damper door located between the refrige and freezer compartment is iced up fully open,you need to defrost it, then see if this closes when the cold control is adjusted
Frigidaire... | Answered on Apr 01, 2014
your ice solenoid is frozen. It is located behind the ice bucket next to the auger motor. It will need to be removed, unfrozen, and squirt a little wd40 to prevent it from happening again
Frigidaire... | Answered on Mar 20, 2014
Hello Linda, I am happy to assist you!
I understand you are seeking a manual for your Frigidaire refrigerator, LGUS2642LF1. I have successfully located the Owner's Guide. I hope this information helps to some degree. Should you need further assistance please feel free to reconnect!
Frigidaire Manual Search Results
Frigidaire... | Answered on Feb 20, 2014
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
341 questions posted
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Carmen Mikulic
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
turned power off house after power
  • Refrigerators
