Setting up new machine and is always coming up with paper jam and there is not one - have checked the cartridges and they seem ok
Hi
unplug the power cable
Press and hold # and 6 on the
printer while keeping these two buttons on hold plug the power cable
back in . when the screen goes off release the buttons and press the
power button to turn the printer on. it ll perform a semiful reset on
the printer .
if the issue still persists then unplug the power cable again
Press and hold OK and CANCEL on the printer while keeping these two buttons
on hold plug the power cable back in . when the screen goes off release
the buttons and press the power button to turn the printer on. If the issue still persists then call hp care they might replace the unit .
If you have cleared off the paper jammed within then it is possible that errors have crept into the drivers. sometimes the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Thanks very much but discovered the machine was faulty. Have now installed my new machine.
