20 Most Recent HP Color Laserjet 3550 Printer Questions & Answers
Set the number of pages to print. You should be able to set the page numbers as well as the number of pages in the printer properties.
HP Color... | Answered on Oct 06, 2017
turn it off, and unplug from power. Then try it.
HP Color... | Answered on Oct 06, 2016
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
HP Color... | Answered on Dec 08, 2015
Try a Maintenance Kit. It will have a new fuser with it and should help with the problem
HP Color... | Answered on Feb 24, 2015
they should be 2 buttons to push in on the sides when u open the tray and pull out
HP Color... | Answered on Sep 24, 2013
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
HP Color... | Answered on May 27, 2013
The Service Menu PIN is 10350003.
HP Color... | Answered on Feb 24, 2013
check the fuser unit in the back of the machine; typically the shadow effect is caused by the fuser assembly. Inspect your toner cartridges for any leaking toner. Genuine HP or ? ? ? ?
HP Color... | Answered on Dec 25, 2012
Try using the HP Print Diagnostic Utility in Windows.
If you need more help post back!
Thumbs and testimonial are welcome!
HP Color... | Answered on Aug 15, 2011
HERE IS YOUR DRIVER ->
HP Color... | Answered on Aug 03, 2011
Welcome to Fixya. I would like to know what is the version of your windows 7 Operating System. Is it 32 or 64bit? Please provide the information needed to be able to fix the issue.
Thanks
77 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
error 13 02 00 paper sticks in fuser
  • Office Equipment & Supplies
