20 Most Recent
HP LaserJet 1020 Printer Questions & Answers
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
HP Laserjet 1020 will not respond - warning light is on (not blinking) and the ready light is off.
Hello, remove the cartridge and check inside the printer, on the left side of the sponge roller about 1 inch/2.5 cm down, there is a lever that engages a flag at the back of the printer ( the sensor in case tells the printer that the cartridge is in the printer) check that lever and make sure it moves freely. If there is a pice of paper behind that lever, when you insert the cartridge the lever will not go all the way.
RESET PRINT COUNT HP 1020 PRINTER
A cold reset should not reset the print count. Those are usually stored in non-volatile memory to prevent scammers from selling used products as new.
Kenapa printer sy laserjet 1020
Asslamualaikum bos ..?
Ane mau sharing ilmu dikit bos..
Saya sebagai teknisi laser ..
Masalah dengan printer nya bos tidak mengeluarkan hasil ..
Udah ganti cartridge tapi hasil nya masih kosong..
Itu bisa masalah di sensor yg ada di dekat power .
Itu bisa sensor nya tidak di kedudukan seharus nya ..
Juga bisa masalah di DC printer nya bos...
terlalu kotor karna tumpah serbuk cartridge nya
SEMOGA BERHASIL BOS
The hp laserjet 1020 the
Open The printer Side Cover. Then Remove Back Plate Of Printer There is Senser On Back Side Check They Are moving or not there is spring in senser
Sir ihave printing problem
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Large black strip printing problem
There is issue with cartridge drum change that drum (It's in blue or green colour). the second option is change the cartridge.
Your issue will be fixed.
Why will the HP Laser Jet 1020 not print?
this is a usual problem with the early models of printers. if you go onto control panel and then printers for the properties then print test page. if this prints fine then you will have to use the add/remove programmes to remove printer software. then delete the printer and install again but not from disc as windows has a package which will do it for you. leave disc in drawer and dont run. just search for the drive whilst installing printer. if this doesnt solve your problem then use the software which you will have to install again. if this doesnt occur then take cartridges out and check if they are correct ones or compatibles as hp not too compatible friendly due to counters.
HP LaserJet Q2612A printer driver needed
The best place to find drivers for any device is always from the manufacturer's website for the product or hardware device you have.
Click here for HP's driver and support website. Another good place to find drivers is
drivers.com. You might also want to check out this site for a free driver scan tool
here. I would suggest trying HP first, then drivers.com and if still no luck try the other one. I hope you find what you are looking for and found these helpful to fix your problem. If you have any questions or need further assistance please feel free to contact me.
P.S. If you would not mind, could you please rate my help as I would greatly appreciate it. Thanks
How to get 300dpi from hp1020 laser
HP support does not list the dpi for its "EconoMode (Save Toner)" setting, however the next highest setting is 600 dpi.
If you are printing drafts and want to save toner, the EconoMode can be chosen in Control Panel from one of your printer's properties tabs.
