20 Most Recent HP LaserJet 3050 All-In-One Printer Questions & Answers
The solution above worked on my printer, without power cycling.
1. Remove all paper from the input tray.
2. Open and close the door.
3. Reinsert the paper into the input tray.
Thanks,
Ilyas
HP LaserJet 3050... | Answered on Jan 21, 2019
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
HP LaserJet 3050... | Answered on May 31, 2018
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
HP LaserJet 3050... | Answered on Feb 02, 2018
thats because vista is out of date and no longer supported. why would you put old software on a new computer anyway??
HP LaserJet 3050... | Answered on Jan 20, 2018
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
HP LaserJet 3050... | Answered on Oct 25, 2017
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
HP LaserJet 3050... | Answered on Sep 27, 2017
Detach the USB cable,un install the drivers,run the CD,connect the cable when connecting dialbox appears,finish it up.. ckeck...
HP LaserJet 3050... | Answered on Aug 23, 2017
No PC model stated
no OS stated (opr. system) windows 10?
we can not help you, ever lacking key facts
why not go to your HP support page and load all software
Related to Laserjet 3050
here
https://support.hp.com/us-en/drivers/selfservice/hp-laserjet-3050-all-in-one-printer/1140783/model/1140778
HP LaserJet 3050... | Answered on Aug 07, 2017
that printer is not compatible with xp,you need to upgrade to at least windows 8
HP LaserJet 3050... | Answered on Apr 19, 2017
The internal memory is full try a nvram.
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
HP LaserJet 3050... | Answered on Sep 22, 2016
please see the exit sensor its broken or displace
HP LaserJet 3050... | Answered on Sep 09, 2016
If the same fault occurs with different printers it is almost certainly caused by the document.
"...second envelope from same document" suggests you are using a mail-merger. Is that right?
What happens if you start again from scratch? Mke a new document and try to print it a a single entity, without using mail merge?
HP LaserJet 3050... | Answered on Aug 31, 2016
Hi vivekchat18,
The instruction below will help you put back the display language you desire for your printer. You may use the procedure below to print out reports or to show messages on the all-in-one control panel. Here's how:
1.First you need to press MENU.
2.Then, select SYSTEM SET UP.
3.Afterward, select LANGUAGE.
4.Now, choose the language that you prefer. In your case, ENGLISH.
5.You have to SAVE your settings.
6.Finally, wait until your system automatically restarts.
Hope it helps.
Thank you for using Fixya.
HP LaserJet 3050... | Answered on May 30, 2016
you mean the ADF unit , for sure but what about it ? i mean whats your question
HP LaserJet 3050... | Answered on Apr 17, 2016
HP LaserJet 3050 All-In-One Printer Logo
957 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
squeaks slight groan when printing need
  • Office Equipment & Supplies
