20 Most Recent HP OfficeJet 6210 All-In-One InkJet Printer Questions & Answers
you must go to control panel of the windows.. then find and click add remove programs.. try to check if any of the printer component are installed.. the remove it.. here's how to install the printer.. 1st don't connect the usb cord to the pc.. then install it.. when the program was searching for the pritner then put the usb cord of the printer.. then so on.. try... ^^
HP OfficeJet... | Answered on Jun 17, 2019
The fax machine needs to hear a dial tone first to send a fax. If you have no fax number, what working phone number are you using?
HP OfficeJet... | Answered on Jan 23, 2018
this is why hp always insists on genuine cartridges. i was going to a storefront inkjet refilling place but with the electronics inside these cartridges, once you use it up, the circuit can be fried. it sounds to me like the internal circuit is done. you may be able to return to vendor
HP OfficeJet... | Answered on Aug 12, 2017
Did you check to see if it had a paper jam?
HP OfficeJet... | Answered on Jun 11, 2017
Try resetting the printer using following steps:
1. When your printer is on, unplug the wire that goes to the computer.
2. Presee and release (#) and (*) buttons.
ou will see your display say "Support Menu"
3. Scrolls to the right until you see "resets" and pess ok
4. Select "semi-full reset" and hit OK
5. After printer turns off, turn it back on 30 seconds later.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
HP OfficeJet... | Answered on Jun 05, 2017
Turn off the HP product and turn it around so the back of the unit faces you.
·Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
·Locate the rear access door and then open it by turning the dial counter-clockwise and then pulling the door toward you.
·Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
Click How to buy on this page to order replacement parts.
·From the rear access door opening, remove the jammed paper. If some of the jammed paper cannot be removed from the rear access opening, carefully remove it from the front of the unit.
·Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
·Reinstall the rear access door.
·Reconnect the power cord to the unit and turn the unit on.
HP OfficeJet... | Answered on May 29, 2017
Check your list of printers and make sure the default printer is the correct one.
HP OfficeJet... | Answered on Mar 18, 2017
Go into the printer driver setup and uncheck print separator page.
HP OfficeJet... | Answered on Aug 11, 2016
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
HP OfficeJet... | Answered on Jul 01, 2016
put HP Genuine Cartridge,align the cartridge,placed the alignment page on the glass correctly
HP OfficeJet... | Answered on Apr 04, 2016
I "inherited" a 6210xi because BOTH hinges were broken... poor and weak plastic design that breaks if the operator tries to raise the access past about 40 degrees for access to ink cartridges... of course after the hinges break it doesn't close properly to start again (except with creative taping!). In my pursuit of these parts I found that the lower hinge part (broken) Part#JB6100289A is actually a Samsung part for their SCX-15 printer/scanner. It was also interesting to find several of these 6210xi's for sale on eBay and other places for $10 or less as "broken, parts only" and AMAZINGLY, it was the same broken hinge part that put all of these out of service. Found the HP Part number as RG5-6317-0000N but couldn't find anything except to buy either the Top half of a whole 6210 or the Bottom half for hundreds of $$'s, far more than the WHOLE new working item would be. UED.net listed the part as "non-stocking" at $2.27 each, available Aug 8, 08, but it turned out to be that they are negotiating for access to that parts and VIOLA! a few months later I received SIX hinges at $2.27 each plus shipping. You have to be creative to keep your old stuff working.
HP OfficeJet... | Answered on Feb 21, 2016
In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
HP OfficeJet... | Answered on Sep 03, 2015
HP OfficeJet 6210 All-In-One InkJet Printer Logo
1,445 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
install software hp officejet 6210
  • Office Equipment & Supplies
